Outside Faucet Leaking, Need A Washer? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2016, 03:12 PM   #1
Rewards Points: 378
Outside faucet leaking, need a washer?
Hello:
My outside faucet is leaking when I turn it on. I think I need a washer, but I'm not sure, thought I would post some pictures.
When I turn it off, no leaks, everything is fine.
Any suggestions?
Thank you,
David
Outside faucet leaking, need a washer?-fullsizerender-62-.jpg   Outside faucet leaking, need a washer?-fullsizerender-61-.jpg   Outside faucet leaking, need a washer?-fullsizerender-60-.jpg
Alumifab is offline   Reply With Quote
Old 07-21-2016, 03:46 PM   #2
Rewards Points: 1,042
Re: Outside faucet leaking, need a washer?
Looks like a freeze proof faucet, here's a link.
http://www.familyhandyman.com/plumbi...aking/view-all
Canarywood1 is offline   Reply With Quote
Old 07-21-2016, 05:11 PM   #3
Rewards Points: 378
Thanks. Not sure why I have them on the house here in Texas, but oh well.
I went to Home depot and they only had a full system replacement.
I'll inspect the faucet more this weekend to see what the issue really is.
Old 07-24-2016, 08:00 PM   #4
Rewards Points: 1,414
Maybe for the anti-siphon effect, or maybe it's what they had at the store. Either way.
Tom738 is offline   Reply With Quote
Old 07-24-2016, 08:06 PM   #5
Rewards Points: 378
Well, I went to Ace Hardware and they had a .89c packing washer that worked.
The other washers on the rod were a little worn, but the guy at the store said, they aren't that bad, no need to change them.
So I first had to dig my main water shut off value from underneath the dirt, haha, yeah it gets a lot of dirt covering it for some reason.
Then I took the rod around until I found what I needed. Lowes and Home Depot were worthless, but my local Ace hardware was great.
I think I'll give him my business when warranted.
Old 07-24-2016, 08:30 PM   #6
What kind of packing did they give you graphite or teflon.
Old 07-24-2016, 08:36 PM   #7
Rewards Points: 378
Honestly, not sure. I know it was black and it fit in the nut perfectly.
Washing Machine Faucet Leaking djods65 Appliances 5 01-25-2014 08:41 AM
4" centerset single lever faucet leaking Ttd0715 Plumbing 3 12-16-2013 05:46 PM
New Moen Cartridge Is Still Leaking on Bathtub faucet rliu Plumbing 7 01-14-2013 08:49 AM
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 01:00 PM
Water leaking in garage everytime we use washer! Please Help shigyrl217 Plumbing 3 12-16-2007 07:03 PM
