Outdoor Shower Tie In - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By jeffmattero76
  • 1 Post By rjniles
Old 08-20-2016, 02:42 PM   #1
Rewards Points: 4
Outdoor shower tie in
Hey everyone,
So I am going to run a hot and cold line to the back of my house for an outdoor shower.
My house is plumbed with PEX.
I found the hot and cold lines for my kitchen sink which I could tie into and run to the back of the house. This would be a long run (about 30 feet and I would have to cut a good bit of drywall to do so.
However I also found the hot water loop for my baseboard heating which is right near the back of the house. This would be more convenient for me to access IF it is possible to tie into.
So my question is - Can I tie into the baseboard heat loop to run hot water to the outdoor shower? Or does the water in this loop not get recycled??
Thank you for your time and help!
Nico
Nicos456 is offline   Reply With Quote
Old 08-20-2016, 02:50 PM   #2
Rewards Points: 18
Re: Outdoor shower tie in
Not a plumber but i dont think you can or should do that. The water that gives you heat is a closed loop, meaning it recirculates the same water over and over.
Sent from my LG-D415 using Tapatalk
Evstarr likes this.
jeffmattero76 is offline   Reply With Quote
Old 08-20-2016, 03:10 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 812
No, the hydronic heating piping is a closed system.
Evstarr likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 08-21-2016, 12:35 PM   #4
Rewards Points: 4
Thanks guys. That's what I figured.
Ok so my next question is how should I run the lines outside?
I was thinking of running the PEX to an anti frost sillcock in hopes to avoid blowing out the line in winter. I was just goin to put a shut uff on the inside and let the frost valve drain as I do with my garden hoses.
Good idea or no?
If it's a good idea, what will I use to get from the anti frost valve which has a 3/4 male fitting, to the shower?
I'm open to all ideas.
Thanks!
Nico
Old 08-21-2016, 08:03 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,818
Garden hose?
lenaitch is offline   Reply With Quote
Old 08-21-2016, 09:58 PM   #6
Rewards Points: 4
That's the reply I was hoping for!
I'd love to use a garden hose. I see they make them for hot water as well.
Any objections?
Old 08-22-2016, 06:58 AM   #7
Rewards Points: 18
How will you connect a shower valve to a sillcock???
Old 08-22-2016, 07:01 AM   #8
Rewards Points: 18
Why not put bleedable shutoffs inside the house and run pex to the shower valve? In the winter, shut off the water inside the house and open the bleeder and the faucet to let the lines drain.
Old 08-22-2016, 07:15 AM   #9
Rewards Points: 4
That's a great idea also. The only concern I had was running PEX outdoors. It will not be exposed to sunlight as I will be running it under a deck. But it will be exposed to some rain, snow etc.
is that ok?
Old 08-22-2016, 07:44 AM   #10
Rewards Points: 18
I believe they have pex that is uv stable, and that can be used outdoors. Go to a supply house rather than a big box.
Old 08-22-2016, 07:55 AM   #11
Rewards Points: 3,292
When using bleedable shutoffs (one version is called a stop & waste) you need to be sure that a "hard wired" line from the shower faucet is continuously descending (may have some perfectly horizontal portions) down to the shutoff.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 08-22-2016, 08:13 AM   #12
Rewards Points: 4
Awesome! Thank you guys so much for all your help!!
Nico
