Old Well Pump Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2015, 01:09 PM   #1
Rewards Points: 36
old well pump removal
Looking for some advice on if the following scenario is something I can tackle or if a plumber needs to be in the picture.
old early 50's house. Still has a outside well and inside pump with holding tank (in basement).
The bacteria counts keep coming back positive/too high so the township says to yank it. I've had a few people come in to look at it and all of them pretty much say the pump is so light duty that it's probably only skimming the surface for suction, not able to pull deep enough and the bacteria counts will likely keep being positive. The costs would be decently high to pull everything out, sink a new point that could accommodate a newer more powerful pump.
Anyway, unless someone can point out a price effective option for salvaging the well system, it seems easier to pull it.
And that leads me to the main question. The state (WI) has a program to aid in the cost for removing the system and filling the well, but who knows when that money will be given out. I'm on a mission to get the basement cleaned up and if the pump will eventually go, why not pull it now?
Like I mentioned, the pump sits on top of a reservoir tank, maybe 30 gallons. Intake from the well comes through the west basement wall about 3 feet up from the floor.
For the folks who know more than me: can the piping simply be cut, capped and the pump removed? or is there more to it? I don't know what the full process is when a contractor would come in and officially fill the well, but it would seem this would be a nice jump start to the process, and would give me more room in the basement!
Any help/advice on this would be great!
militarymedic23 is offline   Reply With Quote
Old 11-29-2015, 02:21 PM   #2
GrayHair's Avatar
Rewards Points: 1,436
I can't offer any help, but state help in closing the well sounds good. Click here
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 11-29-2015, 04:06 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,..... Has anything like dumpin' bleach into the well been tried,..??
Is there a drilled well, with a casin',..??
What diameter casin',..??
If ya cap the pipe, 'n toss the pump, whatcha gonna do for domestic water,..??
Bondo is online now   Reply With Quote
Old 11-29-2015, 04:47 PM   #4
Rewards Points: 36
Iíve already tried shocking a few times. Seems to fit in the description of the pump only pulling from the very top so shocking is just a short term patch. Not terribly excited in trying to test the higher concentrations of shocking, plus the lab would see it right away with bleach levels through the roof.
The actual point is about 10 feet away from the house in the front. I think itís a 6Ē OD pipe going down. Township already has me in their sights with warning letters about not having testing results within acceptable limits.
Iíve done two tests but if the third one comes back positive the lab is regulated to inform the township. So right now the decision to have the well closed is voluntary by me. Seems easier and with more leeway if I do it now vs when they order me to.
The town has my warning letters on hold knowing that I am on the stateís waiting list.
It looks like the city water piping was already in place when the basement was poured. Canít see any sign of a patch job was done to bring it in.
So, city water is already there. Looks like ĺĒ coming in. Decent pricing by the township too.
Maybe 35+ years ago the owners depended on well water, but when I moved in the only thing the well was hooked up to was one external faucet. Given the conversation with the last person for the well eval, the current pump wouldnít be able to handle more than a shower or so. I was able to run a sprinkler on it for the garden, but certainly under matched for pressure offered by the town.
Iím also thinking that with so few other houses within town limits having wells, this may be seen as an added chore for prospective buyers when Iím ready to list. The town requires testing every couple of years.
Old 11-29-2015, 07:20 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 31,594
If the well is only connected to an external faucet and is not being used as potable water who cares if the counts are high. Just don't drink the water.
I never of such thing as "only skimming the surface for suction".
Old 11-29-2015, 07:31 PM   #6
Bondo's Avatar
Ayuh,..... An irrigation well don't need to meet drinkin' water standards,...
Old 11-29-2015, 09:11 PM   #7
Rewards Points: 36
No offense on the wording. I'm sure I'm not conveying the exact wording the contractor used and have botched the wording. The state folks in the area work with this particular contractor quite a bit, so I'm sure he was accurate but I'm not.
hmm good point on the irrigation well. I remember that general thought occurring to me back in the summer when I was working through the initial scenario, but if I did ask about it I think the town shot it down or I would have continued on. I'll call and double check tomorrow.
If I recall correctly, it was coliform count that was above limits. I'd have to look it up again, but if that count is high would it still be ok for irrigation?
Old 11-29-2015, 09:34 PM   #8
Super Moderator
joed's Avatar
Perhaps they meant the well was being contaminated by surface water. That would make sense.
Old 11-30-2015, 10:02 AM   #9
Rewards Points: 36
Pulled this off the township site. Looks like they still need safe results even for outdoor only water sources.
If you have connected to the Grand Chute municipal water system and want to keep your well for outside use, you must have the well tested (twice for coliform bacteria and once for arsenic with a minimum of two weeks between each test) and obtain an operation permit from the Town within one year of such connection. Permit renewals require one of each type of test. To obtain a permit or renewal, please submit safe test results with the fee ($20) to our office.
Old 11-30-2015, 05:44 PM   #10
Rewards Points: 1,852
Cap it thats fecal bacteria. Have your well guy cap it and record it with your town.
Circulator pump: guilty or not guilty? alight9010 HVAC 15 12-28-2015 08:43 PM
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 05:15 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
