Old Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2015, 08:05 AM   #1
Rewards Points: 109
old septic tank
I had my old metal septic tank in my yard collapse last night after some heavy rain. The hole is 4'x4'x4'.What is going to be the best way to fill this in. This has been happening to homes in the area as all these homes were built in the 50's
hitmehhh is offline   Reply With Quote
Old 09-20-2015, 08:13 AM   #2
Rewards Points: 18,962
Was it still in use, or are you now on city sewer?
If it's no longer used around here where made to cut the whole top out, pump out any water and back fill with fill dirt.
Old 09-20-2015, 08:17 AM   #3
Rewards Points: 109
We are on city water and it is not used . I was thinking of filling most of it with crushed stone and the remaining top layer with some topsoil
Old 09-20-2015, 08:29 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
No on the stone. The soil will keep washing down and leave low spots. Fill with plain dirt and then the top soil. If you are paying to have it hauled, it might be cheaper to use all good soil than paying for 2 different loads.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 09-20-2015, 08:33 AM   #5
Rewards Points: 109
How about some sand in the bottom before the dirt for some absorbtion
Old 09-20-2015, 08:42 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
If you use sand you better use at least a foot of topsoil. Else the soil will dry out rapidly and it will be hard to grow grass. Better to try to approximate what is under your existing topsoil.
Old 09-20-2015, 08:47 AM   #7
Rewards Points: 109
I was just thinking a small amount of sand at the bottom for a good base
Old 09-20-2015, 08:52 AM   #8
Sand is not a good base, it's non compactable.
Cheap fill dirt will work fine.
I've had it done to old oil tanks, crock wells and steel septic tanks a few times and it was never an issue.
Old 09-21-2015, 07:20 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,226
Ayuh,.... Sub-soils with abit of clay base,....
'course, I'd be doin' it from the seat of a backhoe, pack the junk dirt in as good, 'n tight as ya can, the tank holds water, so pack the space,...
Then cover with a couple inches of top dirt, 'n scatter some quick-green,...
Old 09-21-2015, 08:30 PM   #10
Rewards Points: 8,651
I might have used whatever the neighbors wanted to get rid of plus whatever spare dirt they had to cap it with.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 09-21-2015, 11:58 PM   #11
Rewards Points: 324
I had to fill one in once, having found it while building a fence--first I used all the unwanted dirt & broken concrete pieces that were on site; that got it about half full, then got some fill hauled in by a local earthmoving guy when he was working nearby, he used his machine to pack it all down as well. It was the cheapest way to do the job.
mgp roofing is offline   Reply With Quote
Old 09-22-2015, 06:09 AM   #12
Rewards Points: 109
I am having some soil dropped off today to get this hole filled. I ordered 3 yards I hope it's enough
Old 09-22-2015, 06:37 AM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
1000 gallons =133.7 cu ft. = approx. 5 cu yds.
If the tank is 1000 gallon (common size), you are short
Old 09-22-2015, 06:50 AM   #14
Rewards Points: 109
The hole is approx. 4' diameter and 4 feet deep
Old 09-22-2015, 06:52 AM   #15
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
About 50 cu ft or 2 yards.
Old Septic Tank davemax Plumbing 3 07-08-2014 05:46 PM
rain water entry direct into septic tank? denemante Plumbing 7 03-13-2013 02:52 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 10:48 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
