Old Kohler Tub Overflow Conversion - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2016, 07:29 PM   #1
Rewards Points: 1,274
old Kohler tub overflow conversion
2 older Kohler tubs, probably both cast iron. One has bigger diameter pop up drain cover. This is lifted by a rocker that is pushed down by a spring barrel in the overflow tube. I assume I have to find Kohler parts for this?
The other tub looks like more common drain with solid barrel that closes and opens over the drain tee - this is what I prefer.
So, are Kohler drain assemblys universally replaceable? Esp the tub that uses the rocker, is it possible to replace that with drain that uses the solid barrel? If possible, I want to use another brand.
That is question 2: brand and supply website recommendation? Delta, Moen, chinese brand(?), that is chromed brass for outside parts and real cast brass and thicker brass tube parts?
Question 3: So, if I have choice, should I stay with traditional drain or change to cable operated or toe operated drain cover? If cable operated, does it need access for repair/replace? If toe operated, is it universally replaceable?
Thank you in advance.
carpdad is offline   Reply With Quote
Kohler sink conversion dinosaur1 Interior Decorating 2 12-30-2011 08:59 AM
Need guidance in readjusting old drain and overflow to fit tub - Pics included amodoko Plumbing 5 12-11-2011 03:25 PM
Kohler Wellworth toilet: spray from overflow Billy2k Plumbing 3 08-26-2011 11:24 AM
"one-hole" bathtub overflow alignment tom31415926 Plumbing 5 07-16-2011 02:46 PM
overflow drain in non overflow sink? forresth Plumbing 1 10-06-2010 06:09 AM
