Old Bend-pipe Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2017, 08:22 PM   #1
Rewards Points: 96
old bend-pipe toilet
Of course, the wrong terminlogy but an old Richmond toilet with a metal angle pipe in back and the water closet sitting on top.
I've been unfortunate enough to have to pull it up to get to the sewer line. Now that I've put it back, it leaks (as expected). Its leaking from both ends of the angle pipe- the top of the where it meets the tank, and where it meets the bowl.
What I'm wondering is if there is any kind of stop leak spray you can spray on the angle pipe and around the large nuts connecting to the bowl and water tank, or even in the tank around the flange, to get this by until the next time it has to come up. At that point, I'll buy a new toilet, OK?
Its just been a huge ordeal getting it back on the wall, and I'd like to not bail at this point. Plus any new toilet will not fit the floor spot and may not even reach from the sewer pipe to the wall, old as this building is.
Since its not under house water pressure and a drain, surely some kind of spray seal would be possible, anyone??
jeffpas is offline   Reply With Quote
gas pipe with slight bend?? Master Brian Plumbing 9 10-18-2015 11:10 PM
Which kind of pipe...What size? maddog1 Plumbing 25 08-24-2015 06:13 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
