Off Set Flange Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2015, 04:05 PM   #1
Rewards Points: 68
Off set flange help
I everyone I need some help with this plumbing in my basement washroom.
I'm trying to install an offset flange toilet. After I broke the concrete i found some problems. If you see the pictures the rough-pipe is 4" and my flange is also a 4", so I do not which is my mistake.
The offset flanges comes in different types of measures?.
How can I solve this?
Thanks!!
pavlito24 is offline   Reply With Quote
Old 04-17-2015, 06:57 PM   #2
Rewards Points: 18,964
Go back and reread your post and see if it makes any since.
Old 04-17-2015, 07:37 PM   #3
Rewards Points: 1,932
Your toilet needs to be 15 inch from the side wall and 12 inch from the back wall. You not moving it that far with any offset flange.
Broken ABS Toilet Flange mnemy Plumbing 7 08-24-2013 11:34 PM
Toilet flange question clambake6 Plumbing 18 03-07-2013 09:25 PM
en Flange bolt. Not sure how to proceed. latenight Plumbing 4 08-07-2012 05:01 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
