Odd Size Cast Iron Hub - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2015, 01:12 AM   #1
Mad Scientist
Odd size cast iron hub
Hey folks, I finally have my very own house to work on, and I could use a little advice.
I've got a completely butchered drain for my kitchen and bathroom, 1.5" PVC going into a cast iron stack. It was leaking badly at the connection between the PVC and cast, and the previous owner had gobbed all kinds of silicone and other various sealants on the joint to try to make it stop.
When I cut all that apart, I found a 1.5" to 2" donut jammed into the hub on the cast iron tee. I figured I could just try replacing it with one that fits a bit better, but I can't seem to find such a thing.
The hub in the cast iron tee measures about 3.25" ID, and all I can find are 2" donuts that have about a 3" OD, which of course won't seal in the hub.
I toyed with the idea of trying to apply a liberal amount of plumber's putty or silicone around the donut, but I doubt it'll work.
Anyone know of a product that'll help me out here?
Thanks!
McSteve is offline   Reply With Quote
Old 04-12-2015, 12:50 PM   #2
Rewards Points: 1,926
http://www.homedepot.com/p/Fernco-3-...5yc1vZbqpfZ4hs
Old 04-12-2015, 01:31 PM   #3
Rewards Points: 8,629
Some times the hubs are an off size and the ferncos wont bite. The one time I encountered that I resorted to oakum and then packed lead shavings on top of that. It was a real PITA and may not work on a horizontal joint.
The only approved way to do it is to go below the hub, cut the pipe and and use a compression fernco coupler. I did not have that option for the fix above.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 04-12-2015, 05:10 PM   #4
I guess you get to cut it out and use proflex band couplings not the all rubber ones.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (04-12-2015)
Old 04-12-2015, 05:14 PM   #5
Rewards Points: 582
pictures are worth 1000 words or in your case an answer to your question
Old 04-12-2015, 09:48 PM   #6
Mad Scientist
I neglected to take a photo of the situation prior, but here's what I've got right now:
That's 1.5" PVC into a 2" reducer into a 2" to 3" fernco, clamped around the outside of the hub. The hub is about 1/4" smaller than the fernco, but I was able to clamp it down enough.
I don't like it much, and I think it still seeps a little around the edge. I might have to cut out the T and replace it all with PVC, but I really don't want to.
Old 04-13-2015, 06:15 AM   #7
Retired Moderator
Rewards Points: 7,174
If you have a plumping supply house close by--call them--my supplier carries sizes that the big home stores don't---saved me several times---
Colbyt (04-13-2015)
2" Cast Iron Shower Drain - Adapter/Options? LowlyDIYer Plumbing 19 10-06-2014 10:41 AM
Cast Iron to ABS - What Coupling? Jaxx Plumbing 1 09-17-2014 05:16 PM
PVC to Cast Iron circa 1985 Perry401 Plumbing 4 07-15-2013 02:09 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
