Occasional High Demand For Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2015, 12:22 PM   #1
Rewards Points: 2
Occasional high demand for hot water
On a few occasions each year our nature center kitchen needs hot water for several hours at a time. The one gas water heater cannot meet that demand but is adequate for most days.
I could add an electric heater ( or two) in series with the gas heater to meet the demand but how should I maintain the additional heater when its not in use?
1) keep running hot water through it ( high standby losses)
2) disconnect and drain the electric heater
3) just let it sit
4) route cold water through it to keep it clean
Or ????
conservationman is offline   Reply With Quote
Old 03-16-2015, 01:41 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 890
Add a second (preferably gas) WH in series with the existing. Water thru the new WH into the existing heater. Keep the new one shut down when not needed.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 03-16-2015, 05:17 PM   #3
Rewards Points: 1,942
Add a larger higher recovery gas hot water tank.
Sell the old one in craigs list if it isn't that old.
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
