Not So Quick Problem... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 3 Post By TarheelTerp
  • 1 Post By joecaption
  • 1 Post By Guap0_
Old 02-17-2018, 04:24 PM   #1
Not so quick problem...
Hello all, new to the forum AND plumbing. I'm no plumber by any means, or a handy man. But I'm getting married soon and trying to save as much as I can in the next 6 months. So I'm Diving in Head first to the world of "I should hire a plumber but I shouldn't" DIY plumbing.
Long story short, I've had a few guys at my local Tru Value tell me how to fix this problem, and every time I go i get a new answer, and spend another $10.
Pipe appears to be semi corroded around the threads, so I can't get anything to thread onto it obviously. Pipe is very old possibly from the late 40s. Can't seem to take it off and scared to honestly since the piece that I took off first basically fell apart in my hands!
Look at the pics and tell me what ya think the solution is!
DumbPlumber69 is offline   Reply With Quote
Old 02-17-2018, 04:27 PM   #2
CodeMatters's Avatar
Rewards Points: 7,942
Re: Not so quick problem...
Try again with the pics.
Not sure but think pics are disallowed from first post.
CodeMatters is online now   Reply With Quote
Old 02-17-2018, 04:55 PM   #3
Yeah your right. working on it!
Old 02-17-2018, 04:57 PM   #4
Old 02-17-2018, 05:25 PM   #5
I'm not a plumber but it looks like there's usable material to connect to
so I expect someone with plumbing experience will be along with a fix.
Good Luck.
Old 02-17-2018, 05:56 PM   #6
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,686
In my house? I'd cut the drain pipe about a foot back (or more)
then... using a Fernco type fitting ... adapt to pvc.
From there it should be a real basic drain fittings
including the fine thread at the tailpiece.
Bondo, Guap0_ and DumbPlumber69 like this.
Old 02-17-2018, 06:04 PM   #7
Rewards Points: 18,960
Is that an old cast iron sink in a basement?
The drain line is plugged up, old steel drain line.
First thing I do when buying a home with that old steel pipe is deduct what it would cost to replace all of it with PVC.
It will leak every time.
In that picture I'm not seeing a trap to keep out sewer gas, no vent.
DumbPlumber69 likes this.
Old 02-17-2018, 06:43 PM   #8
Guapo
Rewards Points: 11,950
I would try Terp's idea first.
Guap0_ is offline   Reply With Quote
Old 02-18-2018, 07:20 PM   #9
I have a Fernco type fitting I picked up. I think it's the right size.
Should I go about cutting the pipe? My fear being that if I cut it and I have to call a plumber that I'll make the situation worse.
No that's the drain pipe! If it was a vent I'd be surprised my home inspector didn't catch it last year when I purchased the home!
Old 02-19-2018, 10:46 AM   #10
MarginallyQualified
I can't answer that Q for you...
but in order to FIT the pvc drain & trap more room is needed.
Start with KNOWING that you can secure the tailpiece...
that the locking nut matches the thread on the sink.
Faint heart never won fair lady.
The key is in using the right tools ... correctly.
A Hacksaw with good blade should be enough.
AFI Problem (Very interesting) Hikyuuri Electrical 9 12-27-2012 07:48 PM
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 09:37 AM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Furnace problem...solution per contractor...please take a look gone_fishing HVAC 5 12-01-2008 05:40 PM
