Not Enough Hot Water To Fill Tub. Just Get A Bigger Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2016, 08:54 AM   #16
You said its gas, no element
dangdave is online now   Reply With Quote
Old 04-01-2016, 09:46 AM   #17
Rewards Points: 1,602
Re: Not enough hot water to fill tub. Just get a bigger tank?
If the real issue is just the tub, you could get a mini instant water heater near the tub. You would either need gas or electric run to the site, but I've seen people that put one near each bathroom. It wouldn't use energy unless you were filling the tub. Might be too expensive for a relatively trivial issue.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
clawlan (04-01-2016)
Old 04-01-2016, 11:03 AM   #18
jlhaslip's Avatar
Rewards Points: 708
Originally Posted by clawlan View Post
I thought about that but the tank is less than 5 years old, manufactured 12/2011.
One town I lived in, five years was about right. Very calcified water.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following 2 Users Say Thank You to jlhaslip For This Useful Post:
clawlan (04-01-2016), de-nagorg (04-01-2016)
Old 04-01-2016, 12:31 PM   #19
Rewards Points: 446
Yea, i thought about getting an in line heater or just replacing the whole tub with a nicer whirlpool with built in heater, but that ends up being a lot more expensive than just another tank.
Again, I'll see what the plumber says after he comes out and sees the exact situation.
clawlan is offline   Reply With Quote
Adding Tankless Water Heater with Hot Water Tank cterrier Green Home Improvement 10 04-14-2017 09:33 PM
Water draining into toilet bowl but not from tank black00 Plumbing 6 09-19-2012 08:28 PM
Low water pressure + storage tank pyotrbee Plumbing 1 08-28-2012 07:02 PM
how to stop drops of water at tank top receptacles? young707 Plumbing 6 08-22-2012 05:41 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
