No Water From Outside Faucet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2016, 06:04 PM   #1
Rewards Points: 12
No water from outside faucet.
My outdoor faucet does not work. There is no valve to shut on/off other than the main house valve. All other faucets in house work. Anyone know why there would be no water? What should I check? Thanks for any tips!
No water from outside faucet.-14623163582692102963530_1462316418745.jpg   No water from outside faucet.-14623164207821730179779_1462316436250.jpg
rey830 is offline   Reply With Quote
Old 05-03-2016, 06:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,056
Re: No water from outside faucet.
Ayuh,.... Either there's another valve to open the outside spigot branch, or it's been disconnected, 'n abandon at some point in the past,.....
Are yer pipes exposed,..??
Follow the pipe back through to the main shut-off, 'n see what's up,....
The Following User Says Thank You to Bondo For This Useful Post:
SHR Plumber (05-06-2016)
Old 05-09-2016, 09:50 PM   #3
Rewards Points: 12
Are your pipes Cast Iron if so there might be a plug from the rust run a wire or something with your water pressure on it will flush out
bisbyte is offline   Reply With Quote
Old 05-10-2016, 06:01 AM   #4
Rewards Points: 1,336
Check under a sink if there is one nearby. Sometimes they put a shutoff for outside faucets under there as that is where they connect to a water source. If you have a basement, check near there in the rafters to see where the connection is.
danpik is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Bathtub faucet won't stay depressed to direct water to shower head ferrugia Plumbing 13 02-27-2013 09:39 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 03:16 AM
