No Flange On Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2015, 07:46 PM   #1
Rewards Points: 2
No flange on concrete
Replaced vinyl tile with ceramic, in a bathroom on a slab. Also replaced toilet, when taking off old toilet there were bolts in the concrete and no flange.
I installed a new toilet with wax ring, and no flange, and it is now leaking at the bottom. Do I need to install a flange to bring the pipe to the level of the ceramic, or can I just use two wax rings.
Thank you ,
JjRacoon
Jjracoon is offline   Reply With Quote
Old 03-28-2015, 08:11 PM   #2
Rewards Points: 2,264
Is the pipe solid and not moving around? Is the toilet solid and not moving around/wiggling?
If so then 2 wax rings)or I would recommend the extra thick instead) or better yet a renovation wax ring which has a plastic extension or 'bell' may work.
mae-ling is offline   Reply With Quote
Old 03-28-2015, 08:54 PM   #3
An old Tradesmen
Rewards Points: 9,504
Moved to Plumbing forum.
Old 03-29-2015, 12:02 AM   #4
Rewards Points: 1,952
Use one no seep wax ring and one all wax ring. Place the no seep directly under the toilet with the all wax ring below it.
The Following User Says Thank You to Ghostmaker For This Useful Post:
mae-ling (03-29-2015)
Old 03-29-2015, 12:40 AM   #5
Here we can get a no seep in a thicker wax ring, then do not need two wax rings
Old 03-30-2015, 08:08 AM   #6
Rewards Points: 3,436
It is very important that the flange not support the toilet otherwise the toilet could get cracked. The toilet should be supported by the floor only.
To make sure the flange does not support the toilet, particularly if the floor should settle or not be absolutely solid, the flange should not touch the underside of the toilet.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
3" ABS toilet flange 3 1/2" too high in basement floor fusion2k Plumbing 3 08-26-2012 12:41 PM
Deteriorated concrete around toilet flange speedy5966 Plumbing 2 05-13-2011 11:01 PM
toilet flange on concrete BlueBSH Plumbing 3 04-19-2011 03:20 PM
toilet flange on concrete amakarevic Plumbing 4 07-04-2008 06:51 AM
