Ng Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2016, 01:29 PM   #1
Rewards Points: 2
ng hot water heater
i have a bradford white defender hot water heater 40g when i light the pilot light sometimes it will go right back out when i let go of the valve and sometimes it will stay on so when it stays on i try to set temp and when it gets to the spot for the burner to ignite the pilot goes out. any suggestions?
jrcat3 is offline   Reply With Quote
Old 04-20-2016, 06:52 PM   #2
Rewards Points: 198
Re: ng hot water heater
Does your Utility come out to service your appliances? Be super careful with Natural Gas...it can kill you. I think you need expert help in this area.
srloren is offline   Reply With Quote
Old 04-20-2016, 07:45 PM   #3
Rewards Points: 3,492
Possibly thermocouple needs replacing. Get out your owners manual and read how to do this. Fairly simple on most water heaters.
When was the last time it was serviced and cleaned to include air combustion filter?
jmon is offline   Reply With Quote
Old 04-21-2016, 08:09 AM   #4
Rewards Points: 3,438
Does the burner try to come on?
Is the inner hatch to the burner compartment sealed?
To replace the thermocouple you have to open the inner hatch. Before you disconnect the pipes and tubes and withdraw the hatch and burner assembly completely, pull the hatch open just a little and try to light the heater again.
Your water heater may have an intake block that activates if cleaning fluid or other flammable liquid is spilled nearby. A replacement part is needed to reset the intake. The heater disabled for this reason will resume operation temporarily if the hatch is left ajar and the gasket (now needs replacement anyway) peeled off. But the heater should not be operated this way awaiting repair parts if the flame has a lot of yellow in it or if the warranty is still in effect.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 04-21-2016, 08:11 AM   #5
deleted ........................................
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
