Newbie..attach Threaded Brass To Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2016, 08:35 PM   #1
yyz
Rewards Points: 50
Newbie..attach threaded brass to copper pipe
Ok so I apologize if my question seems rudimentary. I have a brass threaded ball valve I need to attach to a copper pipe. So, I bought a threaded/sweat copper adapter. When I tighten it by hand, it kind of bottoms out half way. Since the brass part is very expensive I don't want to try forcing it yet. Am I using the correct fitting for this situation? The copy fitting seems to be tapered a bit.
Thanks much, Chris
yyz is offline   Reply With Quote
Old 08-12-2016, 08:41 PM   #2
yyz
Rewards Points: 50
Re: Newbie..attach threaded brass to copper pipe
The manual says to use "male pipe thread x compression fitting"? I haven't seen too many 1 inch compression fittings...
Old 08-12-2016, 09:47 PM   #3
hkstroud's Avatar
Rewards Points: 6,694
Yes
Yes, pipe threads are tapered. The further you screw then in the tighter they get.
Coat threads with pipe dope (pipe thread joint compound) or Teflon tape. Both are lubricants that that aid in tighten.
hkstroud is online now   Reply With Quote
Old 08-12-2016, 09:59 PM   #4
yyz
Rewards Points: 50
Thanks for the info! I thought it was right but I didn't want to wreck my 500.00 fitting...
Old 08-12-2016, 10:06 PM   #5
JUSTA MEMBER
Rewards Points: 3,936
$500.00?
Where are you some remote island where everything is high priced due to shipping?
ED
de-nagorg is offline   Reply With Quote
Old 08-12-2016, 10:07 PM   #6
hkstroud's Avatar
Wow, thought you said brass, must have meant gold.
Old 08-12-2016, 11:24 PM   #7
yyz
Rewards Points: 50
Not gold. just part of my z-wave automatic water shutoff...
Old 08-12-2016, 11:42 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 278
They probably suggest compression so you don't over heat the valve when soldering- you can "boil" the pipe dope out too, resulting in a leak.
Check out 1" MIP sharkbite fittings. They might be a good option
Old 08-12-2016, 11:44 PM   #9
yyz
Rewards Points: 50
Will do thanks. I think I can sweat these without them being attached but I'll look at the sharkbites...
Old 08-13-2016, 06:37 AM   #10
hkstroud's Avatar
I think I would sweat the adapter on , then put a cap on it and check for leaks.
Wouldn't want to be screwing around with a $500 fitting just because I had a leak in a solder joint.
And yes everybody has one every once and a while.
old galvanized pipe, 1/2" and 3/4" copper piping sierra1194 Plumbing 8 11-26-2014 09:01 PM
Grounding to cold water copper pipe joeh Electrical 2 09-12-2013 06:10 AM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
