New Water Shut Off Valve Still Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By joecaption
Old 05-14-2017, 12:21 AM   #1
New Water shut off valve still leaking
Hi, I recently changed a water shut off valve foe my bathroom sink. It still dripping after I replaced it. I can't seem to figure out why. Everything seems tight. Any idea would be appreciated. Thank you.
Asthyanax is offline   Reply With Quote
Old 05-14-2017, 07:07 AM   #2
Rewards Points: 1,054
Re: New Water shut off valve still leaking
Multi turn stop valves suck. Use 1/4 turn ball valves.
Did you clean out the crud that is often backed up at the end of the pipe at the stop valve, especially the hot water side? Crud can clog up multi turn valves and keep them from sealing.
If it is a sweat on valve, they can be damaged from the heat. Best to take them apart if possible or cover with a wet rag when sweating. I prefer to use threaded stops and sweat on a male threaded fitting.
clarenceboddick is offline   Reply With Quote
Old 05-14-2017, 07:43 AM   #3
Rewards Points: 18,952
Where is it leaking, the stem, the outlet, where it connects to the pipe?
MTN REMODEL LLC likes this.
Old 05-14-2017, 10:32 AM   #4
I can't figure out where it leaks but it's a brand new valve. I'll try the switch to a 1/4 turn valve.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 07:52 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 09:47 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
