New Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2015, 04:58 AM   #1
Rewards Points: 2,005
New water line
Apparently , I have a water leak , some where between the water meter ( in the alley ) to the house .
The existing line is copper , in fact , all the water piping inside the house is copper , too . I will probably install the new line to the house in PVC .
Where would I purchase the new " slip nut fitting " that attaches to the " house side " of the water meter ? The existing fitting looks to be brass / copper with the copper water line soldered to it . It unscrews like 1/2 of a union .
Or , if there are no holes in that piece of the copper pipe , do I just adapt from copper to PVC ?
I plan to keep the interior piping in copper
Thanks ,
Wyr
God Bless
WyrTwister is offline   Reply With Quote
Old 12-06-2015, 06:14 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Keep the existing union with a short copper stub. Sweat up to a copper female adapter. Mate to a PVC male adapter.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 12-06-2015, 06:35 AM   #3
That sounds like a plan . :-)
Will know more when I dig it up and can better see what I have .
The house is pier and beam . I know where the existing line stubs up , under the house . But that line probably passes under the concrete back patio and and a concrete back porch .
I will have to pick a more accessible spot ( in an old flower bed ) to stub under the foundation / footing . New ditch in the flower bed to a 24" concrete walk way / border . Under it and continue the new ditch to the water meter .
Under the house , I will install a " Tee " in an existing cold water line and re-feed the house system from a some what different place .
Last thing would be to cut and cap off the spot where the existing exterior water line ties to the existing interior piping .
Thanks ,
Wyr
God bless
Old 12-06-2015, 09:20 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,584
I would not use PCV. If you don't want copper then I would be using poly pipe.
The Following User Says Thank You to joed For This Useful Post:
Ghostmaker (12-06-2015)
Old 12-06-2015, 01:32 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,.... The hi-density plastics are 'bout all that's used up here now a days,....
Contractors, 'n water districts alike,...
pvc is a thing of the past,...
Old 12-06-2015, 04:59 PM   #6
Poly or PEX ?
Why not PVC ? It is inexpensive , available simple technology & I would not need any tools I do not have . And I have run my share of PVC conduit in the past .
I know I would need to use primer , in addition to the cement / glue .
God bless
Wyr
Old 12-06-2015, 06:03 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
In my area (coastal SC), PVC is pretty much the standard for buried water lines. 20 foot, belled ended schedule 40.
http://www.homedepot.com/p/JM-eagle-...2353721?N=bueo
Old 12-06-2015, 07:21 PM   #8
Super Moderator
joed's Avatar
Poly comes in rolls so you would have no connections except at the ends. It's just what we use here for underground water.
Old 12-07-2015, 03:06 AM   #9
I am also considering PEX , for that reason .
Never used PEX , but I have done some research on it , this weekend .
God bless
Wyr
Old 12-07-2015, 06:35 PM   #10
Rewards Points: 1,852
In my area the water provider tells you what you can install.
Ghostmaker is online now   Reply With Quote
Water line running through garage drywall physdl Plumbing 6 07-09-2015 08:50 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 05:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
