New Vanity, First Time DIY. HELP! - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 02-27-2017, 03:17 PM   #1
Rewards Points: 4
New vanity, first time DIY. HELP!
Hello. I recently installed a new vanity in my guest bath. Seemed like it was going to be so simple. Unfortunately, I've been trying to connect the drain to the wall. The p trap and piping (outside of the sink drain) is 1.5" and would connect into the wall without issues. The issue is the alignment. I've been to Lowes and HD 3 times and have been given various direction on how to accomplish my task, but it's still not working out for me. In the first picture, I've attached the drain and p-trap, but would need a 90 bend along with another pipe to get it to the wall. Home Depot told me to avoid 90-bends and suggested a 45 with the rotation of the p-trap to make the other 45 (see second picture). This would work great, but I'm off by about an 1.5". The nut to the 45 I'm using is flush with the nut to the wall (there is a small piece of pipe connecting both). I was thinking about the flexible extension tube from the sink to the p-trap, but have heard mixed reviews. I supposed I could rotate the p-trap more towards the front and then would need some type of connection between the pipe out of the trap and the pipe to the 45. The other issue is that in the picture you see, that's all the space I have for storage under the sink too... and didn't want to fill the whole space with PVC. Honestly, I am tired of going to the store to buy parts, cutting them, and them not working. I've spent about $30 in pipe already... half the cost of the new floors I put in the bathroom. Any help would be greatly appreciated, Thank you.
New vanity, first time DIY. HELP!-img_9215.jpg   New vanity, first time DIY. HELP!-img_9276.jpg
Andals007 is offline   Reply With Quote
Old 02-27-2017, 03:46 PM   #2
Rewards Points: 1,952
Re: New vanity, first time DIY. HELP!
OPen the wall and move the drain?
Old 02-27-2017, 03:52 PM   #3
Rewards Points: 4
I thought about that too, but seems much more time consuming and costly than to purchase a couple more pipes. Plus, this is my first time ever touching plumbing, or ever redoing anything in my house with the exception of paint on the walls. YouTube is pretty helpful until you have a specific and unique situation.
Old 02-27-2017, 04:09 PM   #4
ZTMAN's Avatar
Rewards Points: 628
Just went through the same thing and they guys on here were extremely helpful. I did it once, so now I am an expert.
A simple adapter glued or threaded onto the wall pipe and a 22 degree elbow should do the job.
Another option would be to take the above pics to a local plumbing supply house and they will pull the necessary parts and tell you how to assemble.
Gymschu likes this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 02-27-2017, 04:46 PM   #5
Use a tubular double offset you cut it in the middle and you now have a tubular street 45.
http://www.oatey.com/img/sku/P9046A.jpg
Yodaman likes this.
Old 02-27-2017, 05:53 PM   #6
hkstroud's Avatar
Rewards Points: 6,694
What is the pipe coming out of the wall?
I think I know what that means but not sure.
Move the trap and arm out of the way. Remove every thing off the pipe coming out of the wall that you can and post another picture.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 02-28-2017, 05:08 PM   #7
Tizzer's Avatar
Rewards Points: 148
Why can't the OP thread an 22 angle at the wall pipe.
Might give him the length he needs to connect to the p trap.
Tizzer is offline   Reply With Quote
Old 02-28-2017, 05:33 PM   #8
hkstroud's Avatar
Probably can, that's why I want to see the end of the pipe.
Harold,
Old 02-28-2017, 05:55 PM   #9
ZTMAN's Avatar
Rewards Points: 628
HK is on the case, won't take long figure it out
Old 02-28-2017, 06:35 PM   #10
Tizzer's Avatar
Rewards Points: 148
Same pic. OP's finger is pointing at what "looks" like a threaded on fitting.
Old 03-04-2017, 09:41 PM   #11
Rewards Points: 4
It has a glued adapter for a 1.5" pipe. I'll try to get a pic tomorrow. Thanks.
Old 03-04-2017, 09:47 PM   #12
Rewards Points: 4
Thanks for everyone's input. Still working on this although was put on hold due to late nights at the office. I'll try to get a pic tomorrow of the pipe. I did try to add an extension, but still can't get the alignment correct. Home Depot keeps wanting me to buy the flex pipe. Seems like the easiest solution, but not comfortable with it. For sure a 90 will work perfectly. Not sure about the 22. Sure missed the use of this bathroom last night when my little one was sick.
Old 03-05-2017, 12:22 PM   #13
Rewards Points: 4
The sink drain is about 9 inches from the wall drain (horizontal) and 7.5" from the wall itself. The wall drain sticks out 3" from the wall.
New vanity, first time DIY. HELP!-img_9297_1488738068867.jpg   New vanity, first time DIY. HELP!-img_9301_1488738101173.jpg
Old 03-05-2017, 12:45 PM   #14
Rewards Points: 6,608
If plumbing supplies don't have the rubber adapter you need go to the auto supply and purchase a 1-1/2" radiator hose and use whatever portion of the hose that works for you. Don't forget the 2 worm screw clamps you'll need.
Old 03-05-2017, 02:06 PM   #15
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,712
If you need a 90 use a long sweep 90 and finish up the job.
123pugsy is offline   Reply With Quote
Tags
connecting , p-trap , pipe connection , sink installation , tailpiece
Building HVAC vent into bath vanity nolamar Carpentry 35 02-10-2018 07:58 PM
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 08:13 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 04:13 PM
Offset Vanity Tops miltoda Building & Construction 0 12-19-2011 03:29 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
