New Tank Water Heater - Rusting/Flaking Is This Normal - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By ddawg16
Old 03-10-2018, 02:02 PM   #1
Rewards Points: 244
New Tank Water Heater - Rusting/Flaking is this normal
As the end-user/homeowner I'm not sure if this is something common with new units or something I should be concerned about. Looking through the pilot access I noticed some rusting/flaking. SEE ATTACHED PICS.
Thoughts?
New Tank Water Heater - Rusting/Flaking is this normal-img_7005.jpg   New Tank Water Heater - Rusting/Flaking is this normal-img_7003.jpg
nutshellml is offline   Reply With Quote
Old 03-10-2018, 02:19 PM   #2
Rewards Points: 244
Re: New Tank Water Heater - Rusting/Flaking is this normal
So I sent the pictures to the manufacturer they replied, "The rust appears to be a surface rust, it shouldn’t affect the integrity of the tank. It can be cleaned with a small wire brush and non toxic cleaner. You will maintain your warranty so if you have any additional concerns call us anytime."
Do I actually need to clean it? it's a new unit.
Thoughts?
Old 03-10-2018, 02:59 PM   #3
Rewards Points: 1,932
I wouldn't
Old 03-10-2018, 10:27 PM   #4
Rewards Points: 80
Don't loose any sleep over it.
Cheers!
supers05 is offline   Reply With Quote
Old 03-10-2018, 10:31 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 18,420
This is the bottom of the tank where the flame is?
If so....no, don't sweat it. The moment you start using it...as in, gas flame....all that rust will be burned off.
nutshellml likes this.
Old 03-11-2018, 08:13 AM   #6
Rewards Points: 244
yes, ok great, thank you very much! Second water tank I'm replacing and as such don't know any better (Of course Pops is assisting with the install as last time I did it was when I was 16).
Old 03-12-2018, 03:16 PM   #7
Rewards Points: 3,414
Some water vapor is generated by the burner. This can cause some surface rust under the tank.
Especially if you have a water heater with a sealed hatch and a glass window to look through at the pilot light, it is too much trouble to unscrew the hatch, undo the tubing connections, withdraw the burner, and wire-brush off the rust under the tank.
Also, technically you need a new gasket whenever you open up a sealed hatch water heater although the heater will work perfectly well with the old hatch gasket, or no hatch gasket.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
