New Shower, Old House Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2018, 07:27 PM   #1
Rewards Points: 6
Hello All!
I have recently moved into a home built in 1942. In the basement there is a toilet in space surrounded with concrete block. I would like to turn that area into a shower and toilet. Maybe even have the toilet in the shower, but I am a little hesitant to jackhammer the concrete to put the shower drain and trap in. I've thought about raising the whole area above the floor grade to put the drain in, I am not sure if that's the best idea though.
I was wondering if I could drain the shower into the toilet drain, but I can foresee some issues with smells. I'm not sure the best way to attack this new shower and toilet space. Any ideas would be awesome!
Hex
Hexogen is offline   Reply With Quote
Old 02-18-2018, 07:29 PM   #2
Rewards Points: 6
Re: New Shower, Old House Basement
I'll try to add photos of the space here.
New Shower, Old House Basement-img_20180218_192144.jpg   New Shower, Old House Basement-img_20180218_192149.jpg
Old 02-18-2018, 08:05 PM   #3
Rewards Points: 88
Yep, you will have a stinky room to shower in. The toilet has the "trap" built in to it, that stops the methane gas from coming back out of the sewer pipe it is connected to. Your shower drain will have to have ...a trap. JMO
Gregsoldtruck79 is offline   Reply With Quote
Old 02-18-2018, 08:08 PM   #4
Rewards Points: 6
Thanks for the reply!
Does that mean that I need to break concrete in order to have both a shower and toilet?
Could I build up a raised floor and put a trap underneath it, and extend the toilet flange up up around 8 inches or so? Like a step in shower?
Thanks!
Old 02-18-2018, 08:25 PM   #5
Rewards Points: 88
Not a plumper here, but I don't see why not, if you have the required headroom . Getting the toilet drain extended upwards properly will take some replies from the real plumbers on here.
Old 02-19-2018, 01:23 PM   #6
Rewards Points: 777
How are you going to extend the toilet flange.
ct18 is offline   Reply With Quote
Old 02-19-2018, 03:49 PM   #7
Rewards Points: 2,904
Ooo, Ooo, I know this one!
Google "toilet flange extender" (or search HD or Lowe's web site for it.)
I just ran into those not long ago, never knew they existed but I'm guessing this is what they're for.
CaptTom is online now   Reply With Quote
Old 02-20-2018, 12:08 PM   #8
Breakin' Stuff
Rewards Points: 1,374
You really can't avoid busting up the concrete unless you remove the toilet, build up a base, and put the shower and drain trap above it. And if it's anything like my house from the 40's, there isn't much headroom to work with.
Might be worth contacting a plumber to have them do the slab and drain work. This type of work in not uncommon.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 02-20-2018, 01:00 PM   #9
Rewards Points: 777
That's where I was going with raising up the flange. I have done many bathrooms in basement jobs and breaking isn't that bad.
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
48" Shower Pan over Basement Shower Drain stickfigurefred Plumbing 3 10-30-2011 11:05 AM
Building a cement/utility shower in basement. kadetklapp Plumbing 4 05-04-2011 08:52 PM
new house old basement abkeeper Building & Construction 5 04-23-2008 05:17 AM
