New Shallow Well Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2016, 04:24 PM   #1
new shallow well problems
I just installed a shallow well for irrigation. The well is 30' deep and i get water at 18'. Running one hose with open no more than 3/4 it has fine pressure, if i open it fully then the water pressure drops and the gauge drops to about 2psi. It never loses prime for i can close the bib and it will jump back up.
well.newbie is offline   Reply With Quote
Old 03-04-2016, 04:36 PM   #2
Rewards Points: 18,772
Need more info on what pump your using, what size lines, is there a pressure tank, ECT.
Old 03-04-2016, 05:36 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,614
If the GPH (gallons per hour) of the pump is less than the GPH of water used the pressure will drop.
Also check the water level in the well when the pump has been running. It be dropping too low.
Old 03-05-2016, 10:29 PM   #4
It it a 3/4 (hp) with a 5 gallon pressure tank, 1 1/4" well pipe reduced to 1" after the check valve. The specifics of the pump is 920 gph, 98' head lift, 26' suction head lift...the pump never loses prime, just when opening the hose fully it sounds like the pump starts cavitating until i close it some then its ok, just not full pressure..it took 2min 13sec, to fill 5gallons
Old 03-06-2016, 09:10 AM   #5
Super Moderator
joed's Avatar
You need to check the water level in the well when the pump is running.
Old 03-07-2016, 08:51 AM   #6
SHEPLMBR's Avatar
Rewards Points: 178
pump could be too powerful for what the well recovers. Sometimes bigger isn't always better.
SHEPLMBR is offline   Reply With Quote
Mac Problems l008com PC Repairs & Upgrades 4 06-25-2016 09:17 AM
Power problems on second floor, first floor is fine rarken1 Electrical 21 05-16-2015 11:42 AM
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
