New PEX Pipe Over Old Brass PEX Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2017, 04:35 PM   #1
Rewards Points: 6
Question
New PEX pipe over old brass PEX fittings
The old "1/2" male brass connections on fittings and ball valves in PEX piping in my house are a larger diameter than newly purchased ones.
Today I bought PEX crimping and cutting tools, 1/2 inch Sharkbite tubing, copper crimp rings, and a 1/2 inch Sharkbite brand brass ball valve to replace a leaking ball valve in a home I just purchased. No problem installing the new pipe to the new valve which had male PEX-type connections. However, I could not force the new PEX pipe over the male ends of the old copper fittings and ball valve, particularly when I first put the copper crimp rings near the ends of the new pipe. What has changed and what is the work-around?
pbgvdad is offline   Reply With Quote
Old 11-13-2017, 04:41 PM   #2
retired framer
Rewards Points: 15,210
Re: New PEX pipe over old brass PEX fittings
Are you thinking the gray plastic pipe is old pex. It is not pex and the fittings do not fit each other, There is an adapter fitting for between the two pipes, I think with a valve, you will need to change it and adapt the pipe on the other side of the valve,
Nealtw is offline   Reply With Quote
Old 11-14-2017, 03:32 PM   #3
Rewards Points: 6
Thank you for the helpful information. Please tell me what the old gray plastic pipe is called so I can purchase the correct adapter fittings the next time I need a repair/replacement. I do see that a previous owner used white Sharkbite PEX pipe in some locations. Also, there is red and blue plastic pipe attached to the new tankless water heater he had installed.
Old 11-14-2017, 03:45 PM   #4
retired framer
adaptor from pex to polybutylene
They will be in the same display area as pex, you see the difference and it takes a different ring.
https://www.homedepot.ca/en/home/p.1...000102629.html
Old 11-14-2017, 03:50 PM   #5
Naildriver
chandler48's Avatar
Rewards Points: 3,490
Note the polybutylene barbs are close together and the ring is brass colored, while the PEX part has the rings further apart and a black andonized ring. There may be variations by manufacturer, but there is a difference.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Tags
copper fittings , pex
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Distance between fittings: PEX pipe jklingel Plumbing 12 03-15-2014 05:16 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
