New Kitchen, Plumbing Nightmare - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2016, 07:08 PM   #1
Rewards Points: 36
New kitchen, plumbing nightmare
We just had a new kitchen installed, and we are now trying to get the plumbing hooked up again; problem is, there's not enough vertical separation between the drains and the drain pipe - only about 2-3 inches. There's a garbage disposal that's going to be installed on the right side, and I really need the drain pipe to drop about 6". I think that'd give me enough room for the P-trap and the drainage from the disposal unit.
I'm looking at the drainage pipe, and after it goes through the wall it bends out to the right, towards the cold water line, which is only about 7" away. I don't know what to expect if I rip the wall out and try to do it myself. I'm fairly comfortable with most DIY projects of the construction/drywall/minor electrical work varieties, but this would be my first plumbing project.
House was built in Washington state in '52. Haven't bothered trying to find the studs, as there's so much piping, my studfinder won't do me any good, so I have no idea if the pipes run through studs, or if all the work I'll be doing (or will have done) will be between studs. If anyone has any idea what I might be in for, I'd appreciate your insight.
kyle108 is offline   Reply With Quote
Old 07-04-2016, 07:12 PM   #2
Rewards Points: 36
Re: New kitchen, plumbing nightmare
It won't let me post a picture, but there's one in my album.
Old 07-04-2016, 07:54 PM   #3
Rewards Points: 3,220
If you do open the wall. It will be a good time to replace all the old galvanize pipe you can and replace the supply line shut offs as well. Just a suggestion.
Cant really predict what you will fine in an old 50's house. Just be prepared for anything.
Post pictures as you go along the plumbers here will help you out.
jmon is offline   Reply With Quote
Old 07-04-2016, 08:04 PM   #4
kyle's pic of work in progress.
Old 07-04-2016, 09:00 PM   #5
Retired Moderator
Rewards Points: 7,174
As Jmon suggested, open the wall and see what you are up against.
This a a common problem---we will help you figure out the simplest solution.
Old 07-04-2016, 09:04 PM   #6
Rewards Points: 127
Are you on a public sewer or a private system like a septic tank? If the latter you might want to reconsider the disposal.
jimn01 is offline   Reply With Quote
Old 07-05-2016, 01:24 AM   #7
Rewards Points: 36
We're on the city sewage system.
Honestly, due to contractor delays, our kitchen has been out of commission for almost 3 weeks now, and the wife's getting antsy. I think I'm just going to extend the pipe into the P trap a little longer than it should be for now, and when I get back from deployment in a few months, I'll dig into the wall and see what's there. I'll see about adding the disposal system then, too.
Looking forward to other threads in the mean time, though! Thanks, guys.
Old 07-05-2016, 02:26 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 18,202
Galvanized pipes....that is going to be your next issue.
Have you test fitted the disposal yet? They drain out the side so you might be ok.
Old 07-05-2016, 08:44 AM   #9
Rewards Points: 1,298
Would it help to switch out the disposer to left? Does the disposer drain have to point down (is it keyed, I forget?). The t that has the trap may be modified to fit directly to the drain flange with shorter tailpiece with pvc glue/rubber connector, etc.
carpdad is online now   Reply With Quote
Old 07-05-2016, 11:23 AM   #10
Rewards Points: 36
Measured and test fitted, and it'll put the disposer drain at just about the same level as the bottom of the trap.
Old 07-05-2016, 09:21 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 178
It's just a guessing game until you do this....
Old 07-07-2016, 10:52 PM   #12
Rewards Points: 38
Another very unfortunate situation where the kitchen designer and installer do not know what they are doing and the homeowner is left to sort out their mistakes. Happens all the time. I worked closely with professional kitchen designers for many years on hundreds of kitchens because they knew enough to make sure everything would work with their design. What would have been a relatively simple plumbing adjustment has become a big problem that has to be fixed by tearing through the back of the new cabinet.
At the least, I would insist the kitchen designer and installer provide at no charge, a replacement back panel for the cabinet.
SHR Plumber is offline   Reply With Quote
The Following User Says Thank You to SHR Plumber For This Useful Post:
oh'mike (07-09-2016)
Kitchen sink plumbing: Is this an 'S' trap? jsweet1981 Plumbing 14 01-01-2013 11:06 AM
Kitchen sink plumbing leak bodekms Plumbing 2 11-16-2011 12:31 PM
DIY Kitchen Island Plumbing question bayin Plumbing 6 03-27-2011 09:55 AM
moving the kitchen - connecting plumbing timbo59 Kitchen & Bath Remodeling 0 05-03-2010 10:39 AM
Kitchen Remodel Plumbing johnpma Plumbing 2 06-19-2009 09:13 PM
