New Construction Toilet Installation - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By Ghostmaker
Old 05-18-2016, 06:59 AM   #1
Rewards Points: 45
New construction toilet installation
Hello..looking for some advice and suggestions.
I'll be installing a toilet in my basement. The 4" pipe needs to be cut (it's about 2' tall now) for the toilet flange. Also..the 4" pipe isn't straight..it has a noticeable lean to it. So my questions are...
1. How much of the 4" pipe to I leave above the floor to install the flange to?
2. Being there's not much I can do with the 4" pipe leaning a bit..and tips tricks to make sure I have a good seal? I'm assuming the flange when installed will not be level to the floor.
I've read that the leaning pipe probably isn't that big of a deal as the wax ring should adjust for this. But if there's something I can do now to make sure..I'd like to
A couple of pics
Thanks!
New construction toilet installation-20160516_192712.jpg   New construction toilet installation-20160518_073645.jpg
monsterbash is offline   Reply With Quote
Old 05-18-2016, 07:44 AM   #2
Rewards Points: 1,868
Re: New construction toilet installation
Is that a picture of a 4 inch female flange? Why would you not just get the correct flange that allows one to glue into the interior of your pipe. A 3 by 4 flange.
SHEPLMBR likes this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
gregzoll (05-18-2016)
Old 05-18-2016, 08:59 AM   #3
Rewards Points: 45
Yeah.. It's a 4" female flange.
The 3x4 at HomeDepot fit super sloppy inside a 4in pipe. At least the 4" pipe they have at the store. Even the other 3x4s (drain..plastic toilet flange..etc) didn't seem to fit right.
I mean I could move the flange side to side inside the 4" pipe. It wasn't much..but I could still move it
Is that normal?
Old 05-18-2016, 04:08 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
Use one of these
Fits inside the 4" PVC pipe and has a gasket.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 05-18-2016, 05:55 PM   #5
Rewards Points: 582
Agree with ghost cut pipe flush to floor and install 4x3 hub closet flange inside 4" pipe..
Old 05-24-2016, 08:20 AM   #6
SHEPLMBR's Avatar
Rewards Points: 178
Is that normal?
They probably gave u a 4x3 street flange. Not a hub
SHEPLMBR is offline   Reply With Quote
Toilet installation question. ryanmcl Plumbing 3 01-26-2013 07:49 PM
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
toilet flange installation rcassidy Plumbing 1 11-17-2010 02:12 PM
toilet drain pipe is crooked on new construction smcmurrey Plumbing 5 12-24-2008 08:32 AM
Toilet installation markymark Plumbing 3 08-13-2005 08:37 AM
