New Bathroom Can I Connect To Cleanout In Basement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2015, 10:41 PM   #1
Rewards Points: 18
new bathroom can I connect to cleanout in basement?
My one bathroom 1925 home needs another bathroom.
I would like to add the bathroom directly above the main sewage line that exits my house from the basement. There is a cleanout installed. Is there an easy fitting that I can add to the cleanout to attach the new drain pipes from the new bathroom, or do I need to have it dug out and get new pipe connection added?
Thanks,
Chris
matulch is offline   Reply With Quote
Old 12-28-2015, 05:18 PM   #2
Rewards Points: 1,928
Open up that cleanout and take a picture down the pipe.
Old 12-28-2015, 06:22 PM   #3
Rewards Points: 18
I opened the pipe and it goes down about 1 ft on an angle then T's into a horizontal pipe that runs out of house to city sewer line.
Old 12-28-2015, 06:35 PM   #4
Thats a problem... It looks like its a hole blown through the top of Orange ceramic pipe. Ok for a clean out but not good for a stack drain. Do you have a floor drain close by? It would be easier to break it out and add to if it was close. You need to cut in below the floor.
Old 12-28-2015, 07:27 PM   #5
Rewards Points: 18
Here is a better photo.
Also I checked the horizontal pipe with a magnet and it did not stick. If I connected into this cleanout would I run the risk of breaking the ceramic pipe over time?
I do have some floor drains, but will have to rethink my bathroom location to figure out how the drain pipes will come down through the first floor.
Thanks for your help.
Basement bathroom redo? lheins General DIY Discussions 5 07-24-2015 01:49 PM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Installing a plumbing vent on a basement bathroom Breadmaker Plumbing 4 09-21-2012 08:18 PM
How to rough-in basement bathroom? trekkiejt Plumbing 8 05-03-2012 04:23 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
