Neighbor's Drain Field - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2015, 09:20 AM   #1
Rewards Points: 12
Neighbor's drain field
Hey all. My neighbors have way too many people living in their house and have subsequently taxed their septic system. The last time it was pumped was about six months ago. They have a raised drain field that is about 10' from my property line and I know their system is in trouble again because I can hear gurgling coming from the drain field.
With that being said, I have small ditches running on both sides of my property. On the side by these neighbors I am seeing a gross orangish build up. Is this what I think it is?
MTCourson is offline   Reply With Quote
Old 09-20-2015, 09:35 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 898
The smell should tell you. Talk to the neighbor. If they ignore you, call your local health department.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 09-20-2015, 09:45 PM   #3
Rewards Points: 1,952
Notify your local health department the should send someone out to look at it.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Fix'n it (09-21-2015)
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Replace Drain Field? namderd Plumbing 1 04-20-2008 07:59 PM
