Need A Tool To Remove A Sink Faucet 1-1/2" Nut - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2015, 03:49 PM   #1
DIYer
Rewards Points: 302
Need a tool to remove a sink faucet 1-1/2" nut
I am replacing two sink faucets that aren't that old...Probably 10-20 years old. In this condo, both the kitchen and bathroom sink faucets are the same one-hole type faucet. Both have a large, approximately 1-1/2" nut around a threaded sleeve where the water lines pass through that is recessed and impossible for me to access with adjustable pliers or a crescent wrench. There isn't enough room between the wall and the sink bowl to get either tool in there. I'm convinced there must be a special tool for this. I even bought the orange Rigid 4 in 1 tool from Home Depot but it would not work on this large nut.
I've been googling around and found something called a "basin wrench", "basin buddy" (which looks like the end of the Rigid 4 in 1 tool), and even a "shower valve" wrench. Any one of these might work if I could find the right size and it has to be long enough (8-12 inches) to reach from below.
Any ideas?
thanks!
mystic_cobra is offline   Reply With Quote
Old 08-24-2015, 03:56 PM   #2
Rewards Points: 582
basin wrench like this
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
jmon (08-24-2015), mystic_cobra (08-24-2015)
Old 08-24-2015, 04:11 PM   #3
DIYer
Rewards Points: 302
I just finished digging through my pictures from the trip and I didn't take any of the faucet. :/
Does that work on a range of nut sizes? In case I am wrong and it is actually 1-1/4" or 1-3/4", for example?
Is that a Home Depot/Lowes purchase or do I need to go to a real store like Ferguson's?
Old 08-24-2015, 04:18 PM   #4
Rewards Points: 3,432
Available at any big box store. Some are fixed at certain lenght others are telescopic and can be adjusted to any lenght. It grips around the nut. They work great for situations such as yours.
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
ben's plumbing (08-24-2015), mystic_cobra (08-24-2015)
Old 08-24-2015, 04:27 PM   #5
DIYer
Rewards Points: 302
Awesome. Thanks, guys!
The Following User Says Thank You to mystic_cobra For This Useful Post:
jmon (08-24-2015)
Old 08-24-2015, 06:24 PM   #6
Rewards Points: 582
yep its what you need....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 08-26-2015, 07:20 AM   #7
DIYer
Rewards Points: 302
All of the local stores carry the smaller version that handles up to 1-1/4". I need the one that goes from 1-1/2" on up. None of the local stores carry that one. I couldn't even find it on Ferguson's site. HomeDepot.com has it listed out of stock even online.
I dug around and found it on amazon initially for $49 then through another vendor for $20 plus shipping. I'll let you all know how it goes. I should be back there in a couple weeks.
jmon (08-26-2015)
Srewless faucet handles..anyone know how to remove this one? bobfrommtl Plumbing 3 01-03-2015 06:40 PM
How to remove a drop-in porcelain sink under a countertop? fixingstill Plumbing 17 12-31-2014 06:01 PM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
How to remove the Tub/Shower Faucet Lever Handle? compiler Plumbing 4 03-29-2013 07:04 PM
How do you remove the center of the kitchen sink drain? red321 Plumbing 5 02-03-2013 12:11 PM
