Need Silicone For Grohe Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2016, 01:02 PM   #1
Rewards Points: 278
Need silicone for Grohe faucet?
I attached the manual of the faucet I am about to install.
It doesn't indicate you need any kind of putty or silicone for the faucet base. They do have indicate the drain needs putty with a little picture.
Normally, the water won't make it up the base? Or maybe the base is rubbery, but the faucets I had before with similar setup is hard plastic.
If you think I need silicone or putty, please tell me where to apply it.
It's going onto a porcelain sink.
DIYGST is offline   Reply With Quote
Old 05-09-2016, 05:10 PM   #2
Rewards Points: 1,866
Re: Need silicone for Grohe faucet?
Not on the faucet unless your a person that laps water from the sink all over the faucet to clean it. I usually use a damp rag.
Old 05-09-2016, 05:57 PM   #3
Rewards Points: 278
Hi thanks for your reply. I opened the package and the bottom of the inside base does have a "felt" like ring around the plastic. So it is good to go as is.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Shower faucet putty vs silicone jwiens Plumbing 8 03-23-2016 08:22 PM
Is it ok to test drain of new faucet or should I wait for silicone to fully cure? amateurplumber Plumbing 5 07-21-2015 08:24 PM
Caulking tub shower mj12 Painting 15 04-02-2015 06:44 AM
Kitchen sink faucet - putty or silicone, and where? nthdegreeburns Plumbing 11 07-24-2012 03:45 PM
