Need To Replace All Shut Off Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2016, 09:52 AM   #1
Rewards Points: 488
Need to replace all shut off valves
My mother just bought a condo and all of the hot (weird) shut off valves leak and both hot/cold on the washer so I'm going to help replace them. I've attached pictures, some look like compression some are soldered. What's the best way to tackle this, should I replace these with anything better, could I cut them out or should I try and de-solder them? Something like sharkbites would be easier but are those okay to use?
Need to replace all shut off valves-img_1424.jpg   Need to replace all shut off valves-img_1425.jpg   Need to replace all shut off valves-img_1426.jpg   Need to replace all shut off valves-img_1427.jpg
RyanD is offline   Reply With Quote
Old 04-22-2016, 10:31 AM   #2
Rewards Points: 3,208
Re: Need to replace all shut off valves
Yep. Agree with you ryan. Cut em out and use sharkbytes.
Use push on sharkbyte ball valves and 1/4 turn push on supply valves get rid of those old gate valve types. I have some over 7 years old haven't leaked yet. Just my opinion.
jmon is online now   Reply With Quote
Old 04-22-2016, 11:37 AM   #3
+1
Put new flexible ss supply lines on those sinks as well. Mom will be good to go for awhile.
Old 04-22-2016, 12:17 PM   #4
Rewards Points: 488
Can I do the sharkbite ball valve on the bathroom sink ones too? So, cut it and put the valve on with the other end having a connector to the flexi hose?
Old 04-22-2016, 12:58 PM   #5
FIDO...
Rewards Points: 317
I'm a big fan of Sharkbites, but here's a caution to consider...
To work well, Sharkbites need to be installed on new copper/pex (most ideally), or on very very clean & smooth old pipes.
Point being, those existing copper pipes in your pics would need to be cleaned up really well prior to just slapping on a Sharkbite, or I can almost guarantee it will leak sooner or later.
If there is any gunk/buildup, scratches, dents, or nicks on the pipe, or if the pipe-out-of-round even slightly, he Sharkbite won't get a good seal.
It's most likely totally possible to get those pipes cleaned up good enough, but it's just something to keep in mind as you are considering options - good luck!
Cheers, Chris
Chris130 is online now   Reply With Quote
Old 04-22-2016, 02:16 PM   #6
ZZZZZ's Avatar
Rewards Points: 2,416
Looks like there's a bit of mold there, too. Be sure to clean all that up while you're at it. If you have sensitive lungs (like me), I'd take care of the mold first.
ZZZZZ is online now   Reply With Quote
Old 04-22-2016, 02:17 PM   #7
Rewards Points: 488
Yeah, the guy lived there an didn't do a single thing to the place. It's a mess, he was a little slow so he didn't know how to do anything. Good buy though. :-)
Old 04-22-2016, 02:39 PM   #8
No need to. Just get the sharkbyte push on 1/4 turn supply valves (Same thing basically). You need the straight one not angle. Hook up your flex lines to it. Done.
Possible to replace old (1967) diverter stem and other valves with modern ones? genEus Plumbing 7 09-09-2013 08:22 PM
Heating System Check Valves ajberezo Plumbing 2 04-11-2013 12:13 PM
how to shut off raditor to replace floor dnizzle Flooring 5 03-20-2011 04:19 PM
Rainbird Valves Don't Shut Off C_J_GO Landscaping & Lawn Care 8 06-07-2010 07:35 PM
Shut Off Valves Coach Gordon Plumbing 2 04-24-2006 03:13 PM
