Need To Remove Shower/tub Valve - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By TheEplumber
  • 2 Post By TheEplumber
Old 10-11-2017, 03:50 PM   #1
Rewards Points: 14
Need to remove shower/tub valve
Hi there, I hope someone can help here. I need to remove this unit so I can replace the drywall/new surround. The problem is I can't get the end off, not too sure what comes off.
It's an old style Moen type, I have removed the handle, and behind that, there is a metal plate which rotates on/off that is the thing I can't remove.
Not sure if I can upload a picture here.
Thanks for any help.
Bluestorm is offline   Reply With Quote
Old 10-11-2017, 03:58 PM   #2
JUSTA MEMBER
Rewards Points: 3,780
Re: Need to remove shower/tub valve
You need more than one post to load photos.
A simple ok, will give you more posts, then give us a picture.
Many faucets have escutcheons that hold them to the wall, try to turn the trim covers by hand.
or hidden nuts, we really need to see.
ED
de-nagorg is offline   Reply With Quote
Old 10-11-2017, 04:49 PM   #3
Rewards Points: 14
Thanks for the reply.
I looked everywhere for more screws, no luck.
see if i can get a picture up.
Old 10-11-2017, 04:54 PM   #4
Rewards Points: 14
Hi,
Could you help in how to upload a picture, just not seeing it
Thanks.
Old 10-11-2017, 05:07 PM   #5
Rewards Points: 14
Hi.
think i may of worked how to upload a picture.
Old 10-11-2017, 06:59 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 248
In the center of the stem, inside the round metal piece, is a phillips screw. Remove that and the 2 in the face plate and your done.....
Things might be tight due to scum and mineral build up
de-nagorg likes this.
Old 10-11-2017, 07:07 PM   #7
Rewards Points: 14
Thanks,
Just another question, does the front plate where the phillips screw is comes
off or is it attached to the stem.
Old 10-11-2017, 07:22 PM   #8
Plumber
Rewards Points: 248
It comes off. Then the 2 white fluted pieces come off. then chrome tube and plate can come off in one piece.
Tip- cover your drain if it is large enough for pieces to fall down and lose
de-nagorg and Bluestorm like this.
The Following User Says Thank You to TheEplumber For This Useful Post:
Bluestorm (10-11-2017)
Old 10-12-2017, 01:54 PM   #9
Rewards Points: 14
Hi there..
Got another problem. when i was removing the plate the stem broke,
is there anyway to remove the inside, with out removing the whole body.
Old 10-12-2017, 04:51 PM   #10
Rewards Points: 470
More work than you bargained for I'm sure but if it was my job to do, I'd cut away the drywall to give you access and replace that old valve body with something modern preferably with pressure balance valve and if you have little kids, a temperature control- either Delta or Moen. There are great videos on YouTube that will show you how to do all that so I won't go into detail to explain that process. But there are also pros on here that can help you out. I wonder if O' MIke still contributes. I haven't heard from him in a while, but he is a great source of information if he is still on here.
Jim F is online now   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Bluestorm (10-12-2017)
Old 10-12-2017, 10:14 PM   #11
Rewards Points: 14
Update. I did buy a new one, Moen one, I'm re-doing the batheroom so so that new drywall was not fastened to the wall just testing it, got a bit lucky there. Anyway, the old one was a female type and all the new are male.
so had to do a bit more plumbing to do.
All good now and the drywall still fits.
Old 10-12-2017, 10:25 PM   #12
JUSTA MEMBER
Good call , replacing the old one.
It looked to me like it had been mangled beyond repair, and REPLACE was my next suggestion.
You will like the new better anyway, and wonder what was I thinking trying to use the old wore out one.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 10-13-2017, 05:06 PM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,140
Ive had pretty good luck removing mangled posi temp cartridges from moen valves. One thing in my bag of tricks that I havent had to try yet is heating up the brass where the cartridge sits to soften the rubber pieces and hopefully allow it to slide out easier. Maybe next time.
Journeyman Plumber
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
