Need Price Opinions For Running Main Plumping Line 420ft - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2017, 07:17 AM   #1
Rewards Points: 8
Need Price Opinions for Running Main Plumping Line 420ft
Hello everyone!
I am working on some numbers for us moving out to our 7acre property in central Texas. I am hoping to get your opinions on some of these costs...
How much to run plumping? And what kind of pipe should I use?
420ft of pipe? Or should I go straight from the meter to my home site...which would be 300ft of pipe?
Here are images showing the route options I might take for plumping...
Also...
How much to run electric?
I will need to run electric from the box to house is about 150ft. I have a good friend that is an electrician that wants to help! Yay!!
Thank you for your thoughts!! Just hoping to get rough numbers so my wife and I can begin planning a move in the fall.
bettertogether is offline   Reply With Quote
Old 04-25-2017, 06:55 AM   #2
Rewards Points: 1,336
Re: Need Price Opinions for Running Main Plumping Line 420ft
The best way to get an estimate in your area is to call some plumbers and get estimates. I live in NY so any number I would throw out would not do you any good. What type of plumbing, Water, gas, Sewer???
danpik is offline   Reply With Quote
Old 04-28-2017, 03:33 PM   #3
Rewards Points: 122
I agree, draw up a plan with dimensions and send it out to bid to a few contractor's in your area. You'll get a much more accurate quote that way.
Joeycarnuba is offline   Reply With Quote
Old 04-28-2017, 04:47 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,312
Ayuh,.... Combine all of the earth work into yer bids proposals,...
Yer gonna have somebody dig a foundation hole, or level a slab pad,...
Have them price in the ditch diggin' for the lines,...
Yer Bud can throw the wire in the hole, 'n the site contractor will back-fill it,...
Ditto the water line,....
'round here, HDP(sp) pipe is used, like pex, but heavier stuff,...
1 piece from the meter to the house connection,....
Straight line is cheaper, so long as ya don't have to go around something,...
Bondo is online now   Reply With Quote
De-soldering main water line MikeKy55 Plumbing 15 01-29-2011 01:39 PM
