In Need Of Immediate HELP Basement Sink Issues... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
Old 03-27-2019, 04:41 PM   #31
Plumber
TheEplumber's Avatar
Rewards Points: 286
Re: In need of immediate HELP basement Sink issues...
Originally Posted by Maverick21 View Post
Dang that is cold blooded. Thing is from the 1930's.
Just spoke with a plumber and said he has had ZERO luck with those sinks, typically just break apart when he is working with them.
I'm gonna try to SawZall that Cast Iron Piece off, if things turn bad....sledgehammer then I'll buy a new sink.
Wish I knew how to separate the drain for the washer to it's own drain/pipe...
I never had luck either. That's why I suggested locating a replacement drain earlier- or a replacement sink.
Instead of trying to outsmart that antique, pop a hand truck under it and get it outside and plumb in a nice new sink.
Sent from my SM-G970U using Tapatalk
Old 03-27-2019, 05:13 PM   #32
retired framer
Rewards Points: 15,658
Originally Posted by Cricket View Post
I am seeing page 2. You still can't see it?
Yes I can, when I did that last post I was seeing 1 page but my post #28 was listed but I couldn'y get to it.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 03-27-2019, 08:10 PM   #33
retired framer
That is not usually hard to do some pictures of the drain maybe.
figure 7-14
Old 03-29-2019, 05:49 PM   #34
Rewards Points: 200
I like to close these threads out. Due to limited time/wife upset about the laundry had a plumber fix it...I just feel pride in doing stuff myself $450 later smh 🤦‍♂️ at least it’s fixed. Thx everyone for your help. This is the best forum out there! ✊
In need of immediate HELP basement Sink issues...-99f1a4c1-db13-4fe5-b767-1e2232c362f7_1553899730612.jpg   In need of immediate HELP basement Sink issues...-c3f76102-8ff5-400f-b47a-0c970bc77d5a_1553899750624.jpg
jmon, Chris130, Yodaman and 1 others like this.
Maverick21 is offline   Reply With Quote
Old 03-30-2019, 07:49 AM   #35
Property Mgt/Maint
Rewards Points: 8,202
It looks good. The plumber did you a huge favor by adding a clean out. It would make it super easy to add in a washer stand pipe if wanted.
[political signature removed]
Yodaman is offline   Reply With Quote
Installing an ejector pump for basement sink teeb57 Plumbing 4 10-26-2013 10:46 PM
Drain Q: Basement Utility sink move from one side to the opposite amb1s1 Plumbing 21 03-28-2013 02:06 PM
Exposed electrical wires under sink in basement Dizzle Electrical 18 02-12-2012 04:35 PM
Water coming up through sink in basement bunjr Plumbing 3 01-31-2012 06:33 PM
Replacing basement sink pump kornfein Plumbing 0 04-23-2010 12:56 PM
