Need Help Tapping Into Floor Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2015, 03:19 PM   #1
Rewards Points: 8
Need help tapping into floor cleanout
I built a wet bar in my basement and planned to tap into the floor drain/cleanout in the room behind it for the sink drain. However, the copper/brass (not sure) cleanout plug has roughly a 4" outer diameter, and the PVC piece I bought to screw into that has a 4" inside diameter. It's almost like the floor drain is 3.5", but the stores seem to only sell 3" or 4" (in PVC).
Here's a couple pictures showing the cleanout and the PVC pieces I'm trying to attach to it... http://imgur.com/a/SQ0Wy
Do these different types of pipes just not have a way to be jointed? Will I have to resort to one of those rubber boots (I really don't want to...)? Not quite sure what my options are at this point.
Thanks in advance.
Dannerbo is offline   Reply With Quote
Old 10-03-2015, 06:23 PM   #2
Retired Moderator
Rewards Points: 7,174
Your picture did not post--could you try again?
Old 10-03-2015, 06:34 PM   #3
An old Tradesmen
Rewards Points: 9,502
Try it now.
Old 10-08-2015, 11:00 AM   #4
Rewards Points: 8
Ya, sorry. It wouldn't let me post a link so I had to put a period in it.
I ended up ordering a Fernco donut (like a gasket) that I should be able to stick inside the cast iron pipe in the ground, and then a PVC pipe right down the center of the donut (works on compression). I should be receiving it today. I'll let you know how it goes.
Old 10-14-2015, 02:18 PM   #5
Rewards Points: 8
Donut worked great!
Old 10-16-2015, 07:18 AM   #6
Rewards Points: 3,130
I am not a pro, but I was under the impression that tapping into a cleanout is not legal.
Old 10-16-2015, 07:22 PM   #7
Rewards Points: 1,950
It isn't. You have to maintain the cleanout and if the cleanout is a tee on its back your SOL.
The Following User Says Thank You to Ghostmaker For This Useful Post:
SHR Plumber (10-16-2015)
intermittent tapping noise comoing from underneath the first floor vittorino General DIY Discussions 6 08-02-2015 09:57 PM
Tapping in wall after toilet flush Cisco1911 Plumbing 16 03-21-2015 04:27 PM
Tapping from fridge pyper Appliances 6 01-20-2012 12:46 PM
Tapping noise in wall after flushing upstairs toilets John VH Plumbing 2 01-21-2008 11:24 AM
Tapping a water line for fridge Statecowboy Plumbing 6 10-12-2006 11:45 AM
