Need Help Solvent-welding 4" PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2016, 12:27 AM   #16
Rewards Points: 327
Re: Need help solvent-welding 4" PVC
Originally Posted by TheEplumber View Post
You either have bad fittings, bad glue/primer or wrong process.
I don't know what it is. The 4" just doesn't slide once I get it more than half way in. The first half rotating it in there's some friction. The second half just pushing it is very difficult without the squeeze clamps pulling the pieces together. I bought a 32oz thing of the heavy duty cement today. Maybe the 8oz I was using was too old? It was fluid though and I just bought it recently. It's not like I used it for some other project and it's been sitting there absorbing moisture.
I have more pieces to do. I'll let you guys know what happens. Thanks for all the feedback so far!
Deck is offline   Reply With Quote
Old 07-02-2016, 04:36 PM   #17
Rewards Points: 770
I've been making something using 2" and 3" PVC pipe and caps. Both dry fit loose till half way in also. The caps are Charlotte brand from Lowe's but I don't know what brand the pipe is, the 3" is fairly new but the 2" has been in my garage for years and years.
wptski is offline   Reply With Quote
Welding a steel fence shaftmaster Metal Fabrication 5 02-08-2020 08:02 PM
PVC solvent protection ... dcuser General DIY Discussions 9 09-15-2014 05:33 PM
Petroleum solvent on basement slab cerfsud Concrete, Stone & Masonry 2 12-09-2012 09:50 PM
VOC vs Solvent Staining for Fence JasonCA Painting 11 02-29-2012 03:50 PM
4" PVC to 4" Lead Bend solidhomes Plumbing 0 07-20-2010 12:36 PM
