Need Help To Seal My Basement From Flooding. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2016, 09:54 AM   #1
Rewards Points: 6
Need Help to seal my basement from flooding.
Hi,
I recently bought a home in Watseka Illinois. My lovely home is in a FEMA floodplain.
Sugar Creek is 100 yards away and floods my home when we receive more than 6" or more of rain. Recently (12/30/15) my home was surrounded with 4 ft of water along with everyone in a square mile area.
My basement flooded with 6 ft+ of clean river water knocking out my hot water heater and furnace.
I have one working sump pump that worked tirelessly but it was just recycling water into the lake around my home until the flood receded.
Is there any steps I can take short of building a 20 ft concrete wall around my property to prevent future nightmare's?
I love my home but starting a fish breeding pond in my basement is not a good option.
Thanks in advance for any basement water proofing fix it myself options!
Cheers,
Joe
PCRepairSince91 is offline   Reply With Quote
Old 01-10-2016, 10:01 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,700
There is very little you can do with 4 feet of water surrounding your home to keep it out other than possibly sandbagging or moving to higher ground. But then the sewer will will backup into the basement.
Old 01-10-2016, 12:28 PM   #3
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Wall sounds like it might work, but then you have to run it past EPA , FEMA and the Army Corp....
Where does the water come in from? walls or floor?
Life in the flood plan is made harder by the Army Corp changing things in the idea that they are making things better but really they are making it harder.
Akpsdvan is offline   Reply With Quote
Old 01-10-2016, 12:37 PM   #4
Rewards Points: 66
Sadly, in your situation, there would simply be no way to effectively seal every possible entry of the ground water up that high. I could see a LOT of pumps being used, assuming you have electricity to run them all, through pipes away from the house, but these would need to run 24x7 for period of time needed water to recede.
keithhe is offline   Reply With Quote
Old 01-10-2016, 12:48 PM   #5
Rewards Points: 3,294
Caution: If you succeed in sealing the basement, you may or may not run into a new problem, buoyancy. The entire house, foundation and all, could float like a boat out of the ground, most likely with the foundation cracking as well. When the foundation cracks, then water will rush in like it did to the Titanic and your house will settle back down to approximately the same position it was in originally.
To prevent flooding of the basement you need at least all of this:
1. The foundation walls coated with waterprooofing outside.
2. Sandbagging to keep water from lapping up against the house.
3. A fully working perimeter drain system and sump pump(s).
4. Power to keep the sump pumps in operation and keeping up.
5. All drains below the level of the water outside temporarily plugged. This can be tricky with toilets because the water pressure could burst the wax seals outward; sideways.
The further away from the house the sandbag wall is, the slower the surface water seeping underground will get into the perimeter drain system. In turn it will be easier for the pumps to keep up. Also the less porous the soil/earth/dirt/ground (more clay, less gravel or sand, not hastily backfilled with rocks with spaces in between) the slower the surface water seeping underground ...
Yes, the sump pumps will be recycling the water over and over until the flood recedes but the trick is to retard the total amount of water invading from all sides so that the pumps can keep up.
And now, my short answer to the whole dilemma. Sell the house and move.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
The Following 3 Users Say Thank You to AllanJ For This Useful Post:
Gymschu (01-10-2016), PCRepairSince91 (01-10-2016), Windows on Wash (01-10-2016)
Old 01-10-2016, 01:25 PM   #6
Super Moderator
Gymschu's Avatar
Rewards Points: 514
You're going to spend more in preventing flood damage than you did on the home in the first place. Gotta agree with AllanJ, fix it up as best you can and sell.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
joecaption (01-10-2016)
Old 01-10-2016, 06:24 PM   #7
Rewards Points: 127
Some homes in our area moved all of the mechanicals out of the basement and there are no walls, wood etc. nothing is stored in the basement. When it does flood , nothing gets harmed . Pump it out and dry it out .
jimn01 is offline   Reply With Quote
Old 01-10-2016, 06:45 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,056
Ayuh,.... That's the Only real answer,....
Maybe a 6" trash pump could keep up,.... Donno,....
Old 01-10-2016, 06:49 PM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,478
Can you just convert the basement into a pseudo crawlspace that can be finished with moisture insensitive materials? Move all the mechanicals up a level.
Old 01-11-2016, 06:27 AM   #10
Rewards Points: 6
Yeah, my furnace is already horizontal and raised about 4ft up.
Sump pump failed otherwise the only issue would have been the water heater.
Was considering a tankless water heater on the ceiling of the basement.
My electric box is 10 ft up and hasn't got wet yet.
My home was made in 1926 and only got flooded in 2008 and this year.
The once in a 100 year flood happened twice this year.
Our mayor needs to bribe the army corp of engineers and fix this!
I guess at this point:
1. What's the best tankless on demand water heater?
2. What's the best sump pump?
Thanks for all your input!
Old 01-11-2016, 09:20 AM   #11
Bondo's Avatar
Ayuh,.... They can all fail,....
Think redundant,.... install 2 or more to back each other up, when failure happens,...
The Following User Says Thank You to Bondo For This Useful Post:
PCRepairSince91 (01-11-2016)
Old 01-11-2016, 11:11 AM   #12
Rewards Points: 66
I like the Rennai tankless.
For sump pump, depends on what you have available. IF, you have city water, as it rarely if ever goes out, I would consider a water pressure pump for sump power backup. No batteries or electricity needed. If on a well battery or generator might be only backup.
The Following User Says Thank You to keithhe For This Useful Post:
Old 01-11-2016, 12:04 PM   #13
Rewards Points: 808
NO!
Yo need to not buy a (substantially discounted) house on a flood plain and expect others to take responsibility for your idiocy.
My input would get deleted from this quicker than goose crap slides through a tin horn.
Fools buy on sand.
IslandGuy is offline   Reply With Quote
Old 01-11-2016, 01:01 PM   #14
Rewards Points: 66
Originally Posted by IslandGuy View Post
NO!
Fools buy on sand.
Pretty sure the OP does not need your critique. Lots of people are classified in a flood plain in the US, and moving is not always an option. Try answering the question posed or move to another topic where they ask for a critique.
The Following 2 Users Say Thank You to keithhe For This Useful Post:
PCRepairSince91 (01-11-2016), SeniorSitizen (01-12-2016)
Old 01-12-2016, 09:52 AM   #15
Rewards Points: 6
NO!
Fools buy on sand.
I am just asking advice to fix some things.
How did you perceive I am asking others to take responsibility for my "alleged" idiocy?
Did I ask you to pay for it?
Why are you inputting goose crap thru your tin horn = Seems like a waste of time...
P.S. My home's foundation is on Granite
Tags
basement floor leak water , flood conditions , sump pump
Flooding basement, concrete foundation chrisificti0n Concrete, Stone & Masonry 3 11-01-2014 05:46 AM
Basement Flooding woodman775 Building & Construction 3 08-12-2014 04:29 AM
Should I seal my basement floor? word2yamutha Flooring 5 03-20-2013 04:25 PM
footer drain to crock not draining & basement flooding hallettc Plumbing 0 08-12-2012 05:29 PM
Basement Well Flooding - HELP CarolineR General DIY Discussions 14 10-16-2008 11:33 PM
