Need Help Replacing This Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2016, 07:43 PM   #1
Rewards Points: 99
Need help replacing this valve
Hi, this valve diverts drinking water away from my softener. It is leaking and needs to be replaced. I have very little plumbing experience. My questions are:
1. Is there a specific name for this valve?
2. How easy will it be to replace? Any issues I should be aware of?
19mquinn79 is offline   Reply With Quote
Old 08-01-2016, 08:48 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,818
Re: Need help replacing this valve
It's called a 'saddle valve' and by the rust it looks like it or something nearby has been leaking for a while.
I've never had any problems with them but many pros and diy'ers don't like them and would recommend plumbing in a regular tee and valve. If you do choose to replace it with a similar valve, you're going to have clean off all that corrosion on the pipe down to shiny metal where the valve seats using emory sandpaper, otherwise it will probably leak again. Also, don't be surprised if you have to cut off the old valve because of the rust.
It should be fairly easy to replace since the hole in the supply line is already there. follow the instructions that come with the new valve and/or check the Internet. Obviously, you have to turn off the water first (either whole house or to that line if you have line shut-offs) and expect to get some residual water out of the hole when you pull off the old valve.
lenaitch is offline   Reply With Quote
Old 08-01-2016, 08:49 PM   #3
Rewards Points: 5,682
The bolts on that one will probably need to be cut to remove it. I would replace the pipe in that area with a T and install a ball valve for the water supply.
Replacing a water valve in oil heating system ManofWires15 HVAC 15 01-14-2016 05:17 AM
Replacing motorized valve daconic Plumbing 1 12-19-2012 04:09 PM
Replacing shutoff valve undersink bketros Plumbing 1 03-16-2012 02:52 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Need help replacing shower diverter valve magnolia Plumbing 9 07-12-2008 09:54 PM
