Need Help Replacing Faucet Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 08-28-2016, 07:12 AM   #31
Rewards Points: 271
Re: Need Help Replacing Faucet Cartridge
Originally Posted by Druidia View Post
You're better able to determine the size of the O-ring because you have it and the cartridge with you.
Remove the O-ring. Determine the inner diameter. You can also get the ID of the O-ring by measuring the outer diameter of the cartridge groove (where the O-ring sits). also determine the thickness and OD of the O-ring.
When you have all those 3 measurements (ID, OD, thickness), then browse through any hardware store's website and look for your O-ring. Otherwise, just bring the cartridge and O-ring with you to a hardware store and find one that matches.
I did the same before for two Delta cartridges. They were fine. I only had to replace the O-rings.
Forgot to mention that this repair I did (O-ring replacement) was for a bathroom sink centerset faucet that leaked from under the handle, not for dripping from the spout opening. Another O-ring replacement fixed the leak from the base of a kitchen faucet gooseneck spout.
Druidia is offline   Reply With Quote
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Replacing a Kitchen Faucet pikov22 Plumbing 14 11-05-2013 10:48 AM
replacing shower cartridge crankbait09 Plumbing 27 07-20-2012 07:37 PM
Faucet Cartridge removal -- what should I have done? RippySkippy Plumbing 9 08-20-2009 08:49 AM
cartridge faucet problem. drewhart Plumbing 4 01-15-2009 10:49 AM
