Need Help With PVC To PVC Drainpipe Into Cast Iron - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2016, 01:44 PM   #1
Rewards Points: 32
Need Help With PVC to PVC Drainpipe into Cast Iron
I am installing a new sink. The new PVC drainpipe is 1.5" OD.
When the old sink came out, the existing trap and fittings were thrown out, but if I recall properly, it was also PVC. Now I do remember the old drain pipe was not chemically welded into the PVC in the wall, it was just fitted snugly over (or possibly into) the PVC fitting show in the image below.
That fitting you see is a PVC reducer, (2" ID to 1.5" ID as far as I can tell) fitted into a cast iron drain pipe. I am reluctant to mess with the existing reducer (the one situated in the cast iron pipe) as this place is about 60 years old and everything you mess with has consequences
Anyway, I am wondering, can I get away with just snugly fitting my new 1.5" OD PVC drain snugly into that reducer (it slides all the way in and seems nice and snug), and maybe packing the outside diameter of the reducer with plumbers putty? Would this be sufficient to prevent leaking under the sink?
I am wary of using PVC adhesive as I'll have a real mess on my hands if something else goes wrong later on, (this apartment has been a nightmare!) and I would like to maintain the ability to break it all apart again without having to cut and replace everything, or god forbid, have to cut into the walls or mess with that cast iron pipe.
Thanks!
Need Help With PVC to PVC Drainpipe into Cast Iron-img_20160804_120504.jpg   Need Help With PVC to PVC Drainpipe into Cast Iron-img_20160804_120605.jpg   Need Help With PVC to PVC Drainpipe into Cast Iron-img_20160804_143046.jpg
Kamy is offline   Reply With Quote
Old 08-04-2016, 05:18 PM   #2
Rewards Points: 1,874
Re: Need Help With PVC to PVC Drainpipe into Cast Iron
You need to go get a 1.5 inch pvc trap adapter it will glue into the wall and allow you to fasten the trap so it can be removed if needed.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Kamy (08-09-2016)
Old 08-04-2016, 05:34 PM   #3
Rewards Points: 32
Thanks much! Off to Home Depot (or Lowe's) I go
Old 08-05-2016, 07:02 AM   #4
Rewards Points: 18
Not a plumber but I think you will also need a stub of pvc pipe glued into that fitting in the wall, and then the trap adapter will be glued to that stub. Your new p-trap will then go inside that trap adapter.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 08-06-2016, 05:53 PM   #5
Rewards Points: 2,968
Not necessary. They seller trap adapters with a hub on it's end (to be fitted over a pipe) and adapters with a street connection (to be fitted into a hub fitting), that's why Ghostmaker showed a picture of a trap adapter with a street/spigot connection.
miamicuse is offline   Reply With Quote
The Following User Says Thank You to miamicuse For This Useful Post:
Ghostmaker (08-06-2016)
Old 08-07-2016, 09:02 AM   #6
Rewards Points: 18
Not sure why but i cannot see ghostmakers picture. Can you post a link to one?
Old 08-07-2016, 09:12 AM   #7
Rewards Points: 2,972
I found this - by entering "1.5 inch pvc trap adapter" into a well known search engine!
http://www.homedepot.com/p/1-1-2-in-...D112/100347086
FrodoOne is offline   Reply With Quote
Old 08-07-2016, 10:01 AM   #8
Rewards Points: 18
Thanks. I never knew they made the street type. I have only ever seen and used the kind thst go over a pipe.
Old 08-09-2016, 12:39 AM   #9
Rewards Points: 32
Thanks again Ghostmaker, that was exactly what I needed!
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
Bathtub Recommendations - Cast Iron or other? HandyFrank Plumbing 5 10-25-2011 03:25 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
