Need Help With A Moen Lavatory Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2016, 04:31 PM   #1
Rewards Points: 18
Need help with a Moen lavatory faucet
Hello:
I am hoping someone can diagnose this problem which I have never seen before.
In one of my rental properties, when you turn on the hot water at the vanity faucet it will come out normally while that water is cold ( ie. Before the heated water reaches the faucet). Once the heated water begins to come out the flow is reduced by about 80%. If i turn tbe faucet off and then back on, it stays as the reduced flow. If I wait a few hours, the flow is nirmal again until the heated water reaches the faucet. The shutoff under the vanity is fully open (ball valve). This only occurs on the hot side. The cold water flows normally. Is this a cartridge problem? I plan to call Moen on Monday but i am looking for ideas. Thanks in advance.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 11-19-2016, 04:54 PM   #2
hkstroud's Avatar
Rewards Points: 6,684
Re: Need help with a Moen lavatory faucet
I would say yes. Replace cartridge. An O ring is probably swelling due to heat. You do know that Moen is warranted for life. Ask for new cartridge.
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
jeffmattero76 (11-19-2016)
Old 11-19-2016, 05:48 PM   #3
Rewards Points: 18
Hk - thanks for the quick reply. I will change the cartridge and see if that corrects the problem. Moen has already sent me a couple of replacement c a rtridges that i keep in my plumbing tool box. I didnt have that with me today. Thanks again!
Loose Kitchen Faucet - Single Spout Moen Klammern Plumbing 2 07-01-2015 05:50 PM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
Moen Bathroom Faucet Leaking Under Cabinets Moose916 Plumbing 3 12-10-2014 11:58 AM
New Moen Faucet still has sloooooow drip straightsix Plumbing 4 11-05-2012 08:51 PM
