Need Help Fixing Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2016, 07:41 PM   #1
Rewards Points: 6
Need help fixing faucet
Hello,
I do not have much experience working on pluming but am willing to try if possible, or would someone need to be called?
Thanks in advance for any help.
Need help fixing faucet-image_1471567224089.jpg   Need help fixing faucet-image_1471567239961.jpg
Yakkin is offline   Reply With Quote
Old 08-18-2016, 07:48 PM   #2
Rewards Points: 18,784
Re: Need help fixing faucet
OK, so what's the question? looks like someone has destroyed the stem on the cartridge for some reason
Old 08-18-2016, 07:55 PM   #3
Rewards Points: 6
Yes I believe the handle broke and pliers were used to turn on and off.
My question is what all needs to be replaced?
Will I need specialized tools to do this repair?
I was guessing the cartridge needs replaced but I'm not sure how to remove it.
Old 08-18-2016, 09:21 PM   #4
Rewards Points: 1,856
What you have is a moen faucet. In your top picture you can see the clip with a hole underneath the chrome cover. That is what you need to remove to remove the cartridge. The chrome cover just slips straight off. You can contact moen for a free cartridge they give a life time warranty. 1-800-289-6636
In a replacement cartridge you will see a little plastic thingy. It is used to twist the cartridge right to left so you can hopefully extract it once the clip has been removed.
They can be a true pain to get removed because they tend to stick in the valve.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Yakkin (08-19-2016)
Old 08-19-2016, 07:00 AM   #5
Rewards Points: 18
If the white plastic "thingy" doesnt allow you to pull out the cartrige, you can buy a tool to do it. It acts like a gear puller. A screw on the tool screws into the stem of tje cartridge and uou then turn the collar of the tool and the cartridge comes out. You can definitely buy the tool at a plumbing supply house but i am not sure if the big box stores sell it.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
The Following User Says Thank You to jeffmattero76 For This Useful Post:
Yakkin (08-19-2016)
Old 08-19-2016, 08:50 AM   #6
Rewards Points: 6
I've looked into that tool some and only problem I see is you have to actually screw the end of it into the stem of the cartridge witch I don't think will work here seeing as the end is smushed flat.
I was able to get the cartridge to spin a quarter turn in either direction using the white tool. But am still not able to just pull it out.
Old 08-19-2016, 09:03 AM   #7
Rewards Points: 18
Thinking out loud... Since the existing cartridge is already ruined, you might try screwing a drywall screw into the old hole which will give you a handle. Then use vice grip pliers to attach to that screw head and twist and pull. You also might try spraying some wd40 or similar to lubeicate it. To be clear, you DID remkve the chrome sleeve and the horseshoe shaped retainer, correct?
Yakkin (08-19-2016)
Old 08-19-2016, 09:29 AM   #8
Rewards Points: 6
I ended up just using some lubricant and lots of pulling and wiggling, all the rubber had ripped off and wedged the cartridge in even tighter I think but it eventually broke free and came out. Hopefully the install of the new parts will be more easy now.
Thanks for all the help.
Old 08-19-2016, 09:41 AM   #9
Rewards Points: 18
Thats fine. Moen may send a small packet of silicone plumbers grease with the new cartridge. Of not go to home depot and get some. Grease yhe new cartridge well before inserting it. If hot and cold are reversed after installing the new cartridge, remove it again and turn it 180 degrees. If it comes with directions pay attention to the picture for installation. The stem will have a small "step" on the end. From memory, I believe that step should be in the top position but look closely at the instructions to be sure.
Fixing Leaky Kitchen Faucet smata67 Plumbing 10 02-12-2015 06:23 PM
Fixing squeaky tub faucet Rav Plumbing 3 12-09-2012 10:23 PM
fixing a shower faucet AArkesteyn Plumbing 2 03-31-2012 10:49 PM
Fixing Leaking Faucet matt151617 Plumbing 2 01-16-2012 12:56 PM
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 05:26 PM
