Need Help Finding Fitting For Under-sink RO/DI - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2015, 09:09 PM   #1
Rewards Points: 442
Question
Need help finding fitting for under-sink RO/DI
Need help finding the proper plumbing adapter. On the right is a 1/2" female to 1/2" male inline fitting with 1/4" female "T" with a 1/4" ball valve screwed in. This ball valve supplies water to my RO/DI water filtration system. In my previous house, the sink used 1/2" water connections so it was easy to insert this adapter in-line. But the new house uses smaller connections as you can see on the left. I think these are 1/4"? Maybe 3/8"? I don't know what the standard is.
Regardless, I need figure out how to get the filter set up with this smaller water connector. These are the two options I figure:
1. Get an adapter to go from "small" to 1/2", connect existing adapter, then another adapter to go from the 1/2" back to the small size.
2. Get the same piece as shown on the right, but in the small size in stead of 1/2", with a 1/4" female "T" to screw in the ball valve. I like this option better b/c fewer connections means fewer points of failure.
Anyone know what the "small" size actually is and where to purchase whatever I need?
clawlan is offline   Reply With Quote
Old 11-28-2015, 09:16 PM   #2
Rewards Points: 18,808
Change the main line shut off valve you have not to one with two shut offs and then connect that red line directly to valve.
That other valve you have is not needed.
http://www.homedepot.com/p/BrassCraf...X-R1/202047047
clawlan (11-28-2015)
Old 11-28-2015, 09:23 PM   #3
Rewards Points: 442
Ah, wasn't even thinking in this direction. This would definitely be the most robust method.
I assume I am going to have to turn off the main water supply in order to replace that. I have never done that before and not sure where that shutoff would be... The house is about 15 years old.
Now that I think about it though, it might be nice to have the ability to shut off the RO/DI separately?
Old 11-28-2015, 11:23 PM   #4
Rewards Points: 442
Will the red line fit on the 3/8" connector on that valve you linked? The existing ball valve that the red line is connected to says "1/4".
Old 11-28-2015, 11:34 PM   #5
Rewards Points: 442
This might be a good option if I want to retain the ability to shut the sink and RO/DI off independently. Price is a bit crazy though. I am going to have to check it out in the store to make sure that the small plastic line that goes to the RO/DI fits in that 3/8" compressing fitting though.
http://goo.gl/TlBWm9
Old 11-30-2015, 08:30 AM   #6
Rewards Points: 442
Stopped at Home Depot and they had exactly what I needed. Same valve joecaption linked to but instead of two 3/8" outlets, it has one 3/8" and one 1/4".
I just ordered a new set of filters for the system which should be here later this week,. Once those arrive, I'll get everything installed.
Thanks all for the help.
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Leaking Sink fitting seajay590 Plumbing 3 09-13-2007 08:28 PM
