Need Help Finding "Bendy Coil Piece" - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By jmon
  • 2 Post By Javiles
  • 1 Post By 95PGTTech
Old 06-15-2016, 10:46 AM   #1
First Home N00b
Rewards Points: 202
I have two small hose extensions, which, even with plenty of slack bend in the heat and kink (probably due to the economy brand hose). Does anyone know where i can get these coiled sections (picture one) I have at the end of other hose connections to add to my two issue areas to help maintain a slight bend in the hose end without a full kink?
95PGTTech is offline   Reply With Quote
Old 06-15-2016, 10:57 AM   #2
Rewards Points: 3,486
Re: Need Help Finding "Bendy Coil Piece"
Try home depot or hardware store. I've gotten them right at home depot. You just attached them to your hose. About 5 bucks each.
http://www.homedepot.com/p/Ray-Padul...KFKS/205172395
de-nagorg likes this.
jmon is offline   Reply With Quote
Old 06-15-2016, 11:17 AM   #3
JUSTA MEMBER
Rewards Points: 3,944
I think that I have seen them in BIG LOTS.
A dollar store (kinda).
ED
de-nagorg is online now   Reply With Quote
Old 06-15-2016, 12:35 PM   #4
Another work around is just get the heavy duty spring and put it on the part of the hose where you need it. Available at any big box or hardware store in the hardware dept. They sell them in all sizes.
Old 06-16-2016, 10:36 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
How about you cut the pvc pipe use a ninety degree elbow then attach your hose, you avoid looping the hose.
Bondo and 95PGTTech like this.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Bondo (06-16-2016)
Old 06-17-2016, 10:00 PM   #6
First Home N00b
Rewards Points: 202
You must be some kind of savant or something. Before I even saw this response, the project was already finished exactly like you described. I originally installed all the ends 8"+ above ground so any damage from a lawnmower or other tool would allow me plenty of room to cut clean, union, and repair. I quickly realized any damage would likely occur at ground level and I'd be digging into the ground to make the union and repair.
Here is what I accomplished today, complete with grass-matched spray paint.
The phone makes the color look odd, but in reality it looks identical to the grass around it - I hope in a few months when the grass grows back in lush from the trenching damage, they are hardly seen. The kinking issue is solved, completely. My wife is absolutely ecstatic that these eyesores are no longer so protruding or white (on the one in the center of the lawn, I left the cap we will use when not in use white so as to make it obvious to lawnmower operator. No leaks + happy wife is a win of epic proportions for me. Thanks to all who contributed good ideas and resources.
jmon likes this.
Can I use differrent manufacturer for the evaporator coil? tuanngnt HVAC 5 08-27-2012 06:47 PM
Smallest 3 ton A/C coil size dac122 HVAC 4 02-18-2011 12:18 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 05:30 PM
