Need Help With Adding Sink Next To Washer, Which Overflows Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2016, 09:24 AM   #31
WhatRnsdownhill's Avatar
Rewards Points: 2,220
ok just heat the joint up and pull apart, or cut with a sawsall at the joint line( between the cleanout and the T) and a standard nohub clamp will clamp tight on the outside of the cleanout fitting...
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
JustinRampage (01-29-2016)
Old 01-29-2016, 09:44 AM   #32
Rewards Points: 34
Perfect. Thanks again friend. I really appreciate all of the help.
JustinRampage is offline   Reply With Quote
Old 01-29-2016, 10:08 AM   #33
Old 01-29-2016, 06:23 PM   #34
Rewards Points: 1,950
maybe the pvc was another drain...the 1 1/2 copper coming from the T is proper place for vent, being its original to the house..99% its a vent..either way it has nothing todo with the clogged pipe...there are thousands of houses with no vents before code mandated them and they all drain fine for the most part...
Nahh thats new York plumbing... How could you miss that obvious **** work?
For someone with 26 years experience your not showing it?
Old 01-29-2016, 06:25 PM   #35
We need one simple question answered. You said your KS backed up. Is that the 1.5 inch pipe going verticle that the washer ties into? If so nothing has a vent.
Old 01-29-2016, 06:42 PM   #36
why dont you elaborate on whats wrong?
Old 01-30-2016, 10:26 AM   #37
Rewards Points: 34
Screw it. Heated the clean out off. There is 2" copper pipe running down into what I would assume cast iron. I'm going to just put a new clean out in and a tee for the washer and sink.
Need Help With Adding Sink Next To Washer, Which Overflows Kitchen Sink-image_1454171162983.jpeg
Tags
diy , drain , sink , washer
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Adding Washer and Utility Sink in Basement garvin19 Plumbing 14 08-03-2013 12:31 PM
Adding utility sink for washer drain dcj710 Plumbing 16 03-22-2013 06:52 PM
Adding laundry sink - Can I "T" into washer drain? Koellert Plumbing 7 03-08-2013 06:28 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
