Need Help With Adding Sink Next To Washer, Which Overflows Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2016, 07:36 PM   #16
Rewards Points: 34
Originally Posted by Ghostmaker View Post
What does that pipe go to that connects into the washer box?
You could just run it up for the furnace condensate. It's not a vent. Unless New york plumbers always vent the inlet side of the trap..
Oh yeah. That pipe goes up another 5 inches and ends. It's an extras vent pipe for the washer, I guess. Yet the water from the washer still comes up into the kitchen sink.
Do I need to build that extra vent again when replacing all of the piping?
JustinRampage is offline   Reply With Quote
Old 01-28-2016, 08:52 PM   #17
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you dont need that pvc pipe going up.ditch it...if you have water filling up your pipes till it reaches the kitchen, you might have a blockage somewhere...
WhatRnsdownhill is offline   Reply With Quote
Old 01-28-2016, 08:58 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
If the existing set up was properly vented it might drain correctly.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-29-2016, 12:24 AM   #19
Rewards Points: 34
Do you think that I should cut below the clean out as well and install a new PVC clean out before replacing everything to the washer? Cut above the trap and below, connect the vent pipe back up.
Also, what should I use to connect the PVC to the copper pipes afterward?
Old 01-29-2016, 12:24 AM   #20
Rewards Points: 34
Yeah, I'm hoping that this will fix the problem. If not, I will rent the gas powered snake and give it a go throughout the main line.
Old 01-29-2016, 12:25 AM   #21
Rewards Points: 34
Yeah, it's odd. We snaked the hell out of the line a year back and nothing really turned up.I just figured it was wonky venting.
Old 01-29-2016, 12:57 AM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 18,196
Lets get back to the original problem....water backing up into the kitchen sink
You have a problem....moving the device that shows the problem does not solve your problem.
You need to fix your drain.
We used to have our washing machine in the kitchen. And when we started seeing foam in the sink, we knew the drain needed to be snaked. If I ignored it (found out the hard way), it would eventually come out the drain at the washing machine.
Problems don't go away...they just get worse.
ddawg16 is online now   Reply With Quote
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
JustinRampage (01-29-2016), WhatRnsdownhill (01-29-2016)
Old 01-29-2016, 07:09 AM   #23
that set up is properly vented, the extra pvc is doing nothing...you dont have to cut out the cleanout, they make transition clamps that have a stainless steel band to go from copper to pvc, you will need to goto a plumbing supply to get them, you will need 3 of them to put in the double cross ty...or 2 clamps and run new pvc to the washing machine drain box...your choice..if your going to run new pvc, upsize to 2 inch for the sink and washer drain, vent is 1 1/2 which is good...but first you need to clean out the drain line that is clogged, do it first and solve the backup before changing piping around...
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Old 01-29-2016, 07:16 AM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
You are assuming the pipe going up from the clean out is a vent. We don't know that, it may be a drain from a floor above (and not properly vented). Why would anyone have added that vent on the wrong side of the trap?
The Following User Says Thank You to rjniles For This Useful Post:
Old 01-29-2016, 07:25 AM   #25
maybe the pvc was another drain...the 1 1/2 copper coming from the T is proper place for vent, being its original to the house..99% its a vent..either way it has nothing todo with the clogged pipe...there are thousands of houses with no vents before code mandated them and they all drain fine for the most part...
Old 01-29-2016, 08:08 AM   #26
Rewards Points: 34
Thumbs up
It is a vent going up through the roof. I went up and check out the vent too. It is clear. Like others have said, I'm going to run the snake through the main line first and clear up the kitchen sink issue before redoing all of the plumbing at the washing machine. You all are awesome. I appreciate all of the great tips.
For sure. I'm going to knock out the blockage first before rebuilding. Thanks so much for the advice on the transition clamps. I will track them down today. I'm going to just rebuild the pipes going to the washer. It needs a 2" update.
The only weird thing, to me, is the copper tee fitting currently on the setup. Is it soldered on top of the clean out?
Old 01-29-2016, 08:14 AM   #27
Rewards Points: 34
I agree 100%. I'm going to eliminate the backup/buildup before diving into rebuilding the pipes behind the washer and adding in a new sink.
Old 01-29-2016, 08:40 AM   #28
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Cut out as much of the copper as you can. The scrap value will more than pay for any PVC you need, And have enough left for a case of beer or more
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Old 01-29-2016, 08:43 AM   #29
can you get a closer picture of the top of the cleanout? is the cleanout cast iron or copper?if your buying beer with the mongo( scrap copper) get enough for all..LOL
Old 01-29-2016, 08:57 AM   #30
Rewards Points: 34
Haha I like the way you think.
Well imagine that. I get off of my ass and get a closer look and I can see that it is copper. haha. I'm assuming that i can heat that tee fitting off and camp a new one down to the copper sticking up. Or just clamp a new clean out to the copper pipe underneath and get even more money back in copper.
Maybe I can afford the PVC and a case of New Holland Brewing Dragon's Milk (stout). I would gladly buy you all a round, if you lived in around the Dayton, Ohio area.
Tags
diy , drain , sink , washer
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Adding Washer and Utility Sink in Basement garvin19 Plumbing 14 08-03-2013 12:31 PM
Adding utility sink for washer drain dcj710 Plumbing 16 03-22-2013 06:52 PM
Adding laundry sink - Can I "T" into washer drain? Koellert Plumbing 7 03-08-2013 06:28 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
