Need A Floor Drain Cover - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2017, 03:27 PM   #1
Rewards Points: 381
Need a floor drain cover
Where can I get a floor drain cover that actually fits this drain?
How do you measure?
Zamboknee is offline   Reply With Quote
Old 08-12-2017, 07:21 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 286
Re: Need a floor drain cover
Measure across the center- staring and finishing from the recessed edge
Try here for a replacement or you may need to go larger and trim to fit with a small grinder
https://www.plumbingsupply.com/repla...in-covers.html
protruding outlet, outlet cover cracked custard Electrical 1 07-09-2017 11:33 PM
Patio Cover over pea gravel cement greentrees Building & Construction 6 07-02-2017 08:28 AM
Issue with Weatherproof Cover chris87 Electrical 14 08-05-2016 11:23 AM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Cover modification for older Murray service panel JeffT Electrical 2 05-29-2012 10:43 PM
