Need To Change Out This Pipe... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By hkstroud
Old 11-13-2016, 06:52 AM   #1
Rewards Points: 6
Need to change out this pipe...
Hi all,
I don't really know what this is length of pipe is called...hence the title of this post! Please see the attached pic.
I am installing a pedestal sink to replace a sink that was installed in a countertop; the sink was catty-cornered, so one of these pipes was longer than the other, and it is sticking out so much that it's interfering with the pedestal placement. It goes into the wall and appears to be threaded into another pipe.
I assume I can find a shorter, threaded version of this pipe at Home Depot?
Also, since I believe its the original plumbing and therefore 40+ years old, any tips on loosening the damned thing? There is wainscoting paneling on the wall, and I'm not looking to remove it or have to open the wall.
Lastly, would I install the new length with plumbers tape?
Thanks very much!
AM146 is offline   Reply With Quote
Old 11-13-2016, 07:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,446
Re: Need to change out this pipe...
They should have a shorter length. The question becomes is the actual like that you need right in between premade sizes. You may have to have a specific piece cut and threaded for you. I prefer pipe dope over Teflon tape on cast-iron.
Old 11-13-2016, 07:08 AM   #3
Rewards Points: 5,654
The short pipe you are referring to is called a ( Nipple ) and is commonly available in 1" increments for that length. Shorter lengths are sometimes available in 1/2" increments.
No guarantees in simply un-screwing with a pipe wrench to remove 40 year old pipe.
Yes, use Teflon tape to install the new pipe.
Old 11-13-2016, 07:12 AM   #4
Rewards Points: 6
Thanks for your reply. If I cant loosen the pipe...what's the alternative? I am going to assume it would have to be cut and threaded in place...?
Old 11-13-2016, 07:15 AM   #5
Call a plumber at that point.
Have you drained the pipes? You don't want all that water dumping into the wall cavity.
Old 11-13-2016, 07:18 AM   #6
Rewards Points: 6
Haven't drained the pipes. I shut the water off when I removed the old sink and put the new one in...and I ran into this problem when placing the pedestal for the sink
Old 11-13-2016, 07:55 AM   #7
Rewards Points: 10,456
Going to need a pipe wrench to unscrew it. Vice grips or pliers ain't going to do it.
SPS-1 is online now   Reply With Quote
Old 11-13-2016, 08:14 AM   #8
Rewards Points: 1,528
a pipe wrench and might need to slip a pipe over the handle for extra leverage.. dont be surprised if that pipe you replace is full of corrosion... 40+ years old... it might be time to start saving up for a repipe
ryansdiydad is offline   Reply With Quote
Old 11-13-2016, 08:39 AM   #9
Civil Engineer
Rewards Points: 5,246
My post comes from personal experience, most of it unpleasant. A 40 year old pipe is likely to be frozen in place, probably corroded. Even if you can remove the pipe, it is going to be difficult to clean the female threads in the wall to get a good seal with the new pipe, and if it leaks in the wall after installation, you have a serious problem. If the nipple is internally corroded, you have the potential to twist the nipple with the pipe wrench, ruining the nipple, and ruining the rest of your day.
Consider the option of cutting the existing nipple to length with a hacksaw or pipe cutter, then threading the end using a plumbers die. For a small diameter nipple, you can cut the threads using a hand operated die rather than a power tool (I have done it several times). You can rent the die and cutter if you don't want to buy one. Make sure you fully understand how to cut the threads, you are only going to get one chance to do this, so read the directions and go slowly. Use the recommended cutting oil when you thread the nipple.
Old 11-13-2016, 06:34 PM   #10
hkstroud's Avatar
Rewards Points: 6,684
Does anyone know whether this pipe galvanized iron or is it copper?
Everyone seems to be assuming it is iron.
bob22 and MTN REMODEL LLC like this.
hkstroud is offline   Reply With Quote
Old 11-14-2016, 08:01 AM   #11
Given the drawing he reference, I am assuming it is black pipe, but you ask a valid question.
How about a picture @AM146 ? That will help us confirm what you are working with.
Change Pipe to 3/4"... markw8500 Plumbing 11 03-01-2014 03:14 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
Whatís the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
