Need Advice On Changing Location Of Bath To Shower Diverter - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2014, 12:14 AM   #1
Question
Need advice on changing location of bath to shower diverter
I am remodeling a bathroom that has a showerhead, pressure balance valve, and tub spout with diverter. I would like to replace this setup with a new showerhead, pressure balance valve with bath/shower diverter, and tub spout. My question is what plumbing rough-in modifications are required (if any) to relocate the diverter from the tub spout to the pressure balance valve? I have included sample before and after pictures to depict the existing and desired location of the diverter.
For example, do I need to install a pressure balance rough-in valve with built-in mechanical diverter? And if so, is there an existing tub rough-in valve with mechanical diverter that needs to be removed and replace with something different?
Need advice on changing location of bath to shower diverter-before-01.jpg   Need advice on changing location of bath to shower diverter-after-01.jpg
shack623 is offline   Reply With Quote
Old 01-22-2014, 03:46 AM   #2
Retired Moderator
Rewards Points: 7,174
Post a link to the installation instructions for that unit.
Old 01-22-2014, 05:43 AM   #3
Rewards Points: 286
If you move the diverter from the tub spout to the valve, you need a valve with a built in diverter and a spout without the diverter. Nothing out of the ordinary.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
oh'mike (01-22-2014)
Old 01-22-2014, 06:58 AM   #4
Retired Moderator
I looked up that brand---standard installation---
However, where will you be able to find parts for that ?
Shower mixers need servicing in 5 to 10 years---can you find parts locally now? In 5 to 10 years?
Not wise to use a nonrepairable unit----check with your plumbing supply house about parts----
Tags
bath and shower , bath remodeling , plumbing rough-in , shower diverter
Advice on tile to fg shower pan seal needed imautoparts Tiling, ceramics, marble 3 11-21-2012 11:29 AM
location of bath switches/ how far from shower mazey Electrical 2 06-29-2011 01:27 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 07:06 PM
