Need 2" Tub Drain Assembly - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2019, 04:54 PM   #1
Rewards Points: 2
need 2" tub drain assembly
I have bought a solid marble tub, and am running into issues getting it installed. The assembly that came with it (bought from an importer guy, supposedly, and had a drain with it. problem is that set the pop up won't reach the tub to seal. bought a piece from kohler, but it is 1 1/2 inches long, and the tub is really thick so it isn't long enough to get snugged in right. Plumber says I need a 2" pipe, about, but it doesn't seem they make one. Any suggestions?
hudley is offline   Reply With Quote
Old 07-01-2019, 08:02 PM   #2
retired framer
Rewards Points: 15,210
Re: need 2" tub drain assembly
Is this what you are looking for.
https://www.plumbingsupply.com/drains.html#exthread
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 07-02-2019, 07:31 AM   #3
Rewards Points: 4,368
If you're having trouble finding a long enough drain you could adapt a vessel sink popup drain—it's easy to find those with long tails.
huesmann is offline   Reply With Quote
Tags
2" drain , drain assembly , marble tub , pop up
