Navien NPE-240A Question. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2016, 08:06 PM   #1
Rewards Points: 20
I'm installing a Navien NPE-240A and had a question about the internal/external re-circulation modes. I'm running a re-circulation line, do I use "internal" re-circulation mode or "external"?
Thank you!
Mike
mik123je is offline   Reply With Quote
Old 10-12-2016, 10:22 PM   #2
Rewards Points: 80
Re: Navien NPE-240A Question.
External mode.
Pages 21-23 in the manual. You have to close the internal recirc valve and set the dip switches accordingly. (number 1= off, number 2 = on)
Cheers!
supers05 is offline   Reply With Quote
Old 10-13-2016, 06:02 AM   #3
Rewards Points: 20
Thank you! One more thing, seeing that the re-circulation line is considered a closed loop system should that have a 2 gal. expansion tank on it as well?
Old 10-13-2016, 08:09 AM   #4
Rewards Points: 80
I'm not familiar with expansion tank sizing, but yes, there should be one somewhere on the hot side. (even if you don't use the recirc loop, there's a check valve in the inlet, so it needs one)
Cheers!
Old 10-13-2016, 04:14 PM   #5
Rewards Points: 1,862
Strange never required an expansion tank on a on demand hot water heater. Because it is only producing hot water when a valve is open. So no pressure can develop. But each area his own I guess.
Old 10-13-2016, 05:13 PM   #6
Rewards Points: 80
These are often used for combi units. (both hot water and space heating)
You're right, if it's only a instant hot water heater without a recirc line, you should be fine without an expansion tank.
Cheers!
Old 10-16-2016, 04:25 PM   #7
Rewards Points: 20
Need to fill the condensate trap? Pour water down the exhaust pipe?
Old 10-16-2016, 07:12 PM   #8
Rewards Points: 20
Well...she is all fired up and running like a dream! Thanks for all the help!
Mike
Old 10-18-2016, 09:47 PM   #9
Rewards Points: 80
Sorry, I didn't see it in time. Not that I know of. They condensate almost immediately. (you'll know if you forget to connect the drain line, lol) I've never worried about it. They usually burn real nice and clean at the beginning too, so CO is usually way down. (usually 3-10ppm) Not much to worry about.
I'm glad its all working for you. They are real easy to install and get going. Fixing them.... That's a different story, lol.
Cheers!
Navien tankless waterheater exhaust pipe freezing robo11 Plumbing 15 01-16-2015 07:32 PM
Navien 240a trish paris Plumbing 5 06-03-2013 12:42 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
condensing tankless water heater: navien, noritz, bosch rny1diyc Plumbing 0 09-07-2012 04:48 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
