Natural Gas Firepit Hook Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2016, 05:52 PM   #1
Rewards Points: 373
Natural gas firepit hook up
So I have 1/2" black pipe stub out in the middle of my firepit. They put a 4" vertical piece of pipe at the elbow but I need to add 12" of pipe to get the fire ring to the proper height. We are putting gravel in the pit 3" from the top and then fire glass (2-3") over the fire ring. The issue is the pipe is not plumb so the ring is 3/4" higher on one side. Can I use flex to make the connection from the black pipe to the Fire ring so it's level? Will I reduce the gas flow using flex vs 1/2" black pipe?
titan7 is offline   Reply With Quote
Old 03-12-2016, 07:44 PM   #2
Rewards Points: 582
Re: Natural gas firepit hook up
at the lowest point of gas hook up..use a 1/2" 45 and a 1/2" st 45 to plumb up the riser then get the proper size nipple for the right height... I would not use flex in that case..
Old 03-12-2016, 08:49 PM   #3
Rewards Points: 373
That's a good idea but I can't twist the 90 off because it's too close to the concrete floor.
Old 03-13-2016, 12:33 AM   #4
You can leave the 90 in place and use the 45's as a swing joint. You may need to use a couple more 45's if you want the fire ring centred exactly where the 90 is. If you can, tighten the 90 to give you the first 45 angle. I wouldn't use a flex either.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
ben's plumbing (03-13-2016)
Old 03-13-2016, 06:51 AM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
is this fire pit outside? how did they run black pipe to it? if its outside the gas pipe at least should be galvanized or it will rot out and you will get a gas leak..
WhatRnsdownhill is offline   Reply With Quote
Old 03-13-2016, 08:01 AM   #6
Rewards Points: 582
leave the 90 and use a short nipple for the 45s'''
Old 03-13-2016, 12:46 PM   #7
Rewards Points: 373
They used 1" PE gas pipe from the meter underground to the valve on the side of the fire pit and the above ground stub out. They just did not ensure the vertical pipe was plumb. It's centered in the firepit with is good but one side of the fire ring is 3/4" higher than the opposit side. Not sure if the mason messed it up or it was not plumb to begin with.
I will try the 45 and hopefully the will bring it plumb. If not its flex or the ring will be uneven, hopefully the will not impact the flame.
Old 03-13-2016, 03:02 PM   #8
Rewards Points: 373
Tried the 45, it tilts the pipe the opposite way too much. So options are leave it out of plumb its, actually only about 1/4" out of plumb in a foot. The fire ring will be buried under 2-3" of glass, so hopefully the flames will not be different on each side?
Option #2 is 12" piece of SS flex gas line going from the black pipe to the fire ring, then I can level the fire ring on the gravel.
Any downside to flex? They make a whistle free and high capacity. Not sure if there is any difference between they?
Last question, using pipe dope, on the connections, how am I to do the soap water test on the connections if the fire ring is connected as I can't plug the holes?
Thx
Old 03-13-2016, 04:04 PM   #9
Can you post a picture of what you did? There's no reason you can't hard pipe it perfectly plumb.
Old 03-13-2016, 07:56 PM   #10
Rewards Points: 582
45s or 90s should make a swing joint to plumb you up.. pictures...
Old 03-13-2016, 09:04 PM   #11
Rewards Points: 373
Here are some pictures. Let me know what you think. I want to keep the fire ring centered within the pit. I figure I could be done with black pipe but that will be a lot of connections. Would have been nice had they installed this plumb, lol.
Old 03-13-2016, 10:17 PM   #12
Easy peasy. (Use approved dope/tape on all male pipe threads).
- cut the tape off half way down the 90
- remove the 4" nipple
- turn the 90 almost 45 (but not quite because you'll plumb it up later)
- add a 1/2 " X 1 1/2" nipple and 1/2" 90 and tighten, but not quite all the way because you'll plumb it up later.
- add a 1/2 X 45 with a nipple long enough to centre the fire ring and tighten in line with the 90
- add the final nipple (it'll be shorter than the 12" you had, maybe ~10"?)
- plumb up the line by tightening the 90's
- cap the nipple and soap test
- wipe dry and wrap with approved tape (polykin, tbt20, Denzo, etc)
Boom. Two extra fittings.
titan7 (03-13-2016)
Old 03-13-2016, 10:33 PM   #13
Rewards Points: 373
Thanks, I will pick up the fittings and give it a try.
Old 03-13-2016, 10:44 PM   #14
Do or do not. There is no try.
Old 03-14-2016, 08:51 PM   #15
Rewards Points: 373
Okay I tried to move that 90 at the bottom, that thing is not moving, I just can't get adequate leverage as its so close to the floor.
So, here is a redneck solution, there is some play with the pipe I can make it nearly plumb by pushing down on the high side of the fire ring. I could just put a piece of pipe halfway up the vertical pipe that braces between the inside wall of the fire ring and the pipe?? Not sure if that's bad for it? It not flexing it a lot, maybe 1/4". I know, not the best fix but it worked as long as there is no long term issue for the pipe?
Other than that, it flex pipe, or I need to call in a pro.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
How to hook up an existing gas fireplace amers_j HVAC 0 11-02-2012 09:26 AM
Is Natural Gas Firepit on a Wood or Composite Deck unsafe? Jakobud General DIY Discussions 4 03-29-2012 03:43 PM
Refinishing Natural Oak Cabinets without stain Ceo Painting 2 07-10-2011 10:52 AM
Natural Gas Firepit tbrown1110 Plumbing 2 04-11-2010 01:07 PM
